Dx Blame ST together Dx Super A
Old 19th January 2014, 02:53 PM   #1311
Bigun is offline Bigun  Canada
Bigun's Avatar
How do you like the sound ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 19th January 2014, 08:28 PM   #1312
cjkpkg is offline cjkpkg  United States
Man I can't wait to fire it up! Maybe tonight or tomorrow...need to finish fabricating my L channels to mount to heatsink.
Old 19th January 2014, 09:07 PM   #1313
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Don't forget to set up the bias trim pot to the highest resistance and also use a lamp to protect the circuit I'm making one for my diy projects good luck sir
Juan
audio fanatic only
Old 20th January 2014, 10:25 PM   #1314
Well I finally got the amp fired up! So farso good...although even at 40v+/- I can only get the bias up to 170mA. I have a 200 ohm pot so iguess I need to adjust the 680 ohm resistor...increase right? I always get that mixed up....
Offset is hovering right around 10mv or less
Anyways the amp sounds really nice and is very quiet.
Here's a pic...still need to clean upmthe rats nest.
Old 20th January 2014, 10:40 PM   #1315
Am I better off dropping the 2.2k resistor or increasing the 680r to maybe 1k? Not sure if there is something magical about the value of the 2.2k resistor.
Old 21st January 2014, 03:06 AM   #1316
oh my God ! 10mV offset wow man looks really nice, 40V power supply is ok I'm running the ones I have at 43V, Carlos hasn't seen this yet he will love it!, hey rapid question here, did you use white thermal paste from L shape adapter to the main heat sink ? it looks really clean
About the 680 ohms resistor probably you can lower it to 500 ohms because you are using 40V +/-
the voltage I read from the 10 ohms resistors in place of the fuse on my boards I always adjust them to about 2.5V +/-
Juan
Juan
audio fanatic only
Old 21st January 2014, 10:05 AM   #1317
The Vbe multiplier output voltage, or bias voltage, is given by:
Vbe * [Rupper + Rlower] / Rlower
If Rlower is a 680r and a 1k VR, then the bias voltage can range from:
[2200+680]/680 * Vbe, to [2200+680+1000]/[1000+680] * Vbe, i.e from 4.24Vbe to 2.31Vbe
If you maximum bias voltage is too low to turn on all the output transistors then you can increase Rupper and/or decrease Rlower.
regards Andrew T.
Old 22nd January 2014, 01:59 AM   #1318
OK guys...I re read much of the thread and finally realized that the goal is 250 mA per rail, not device.
I am stable now at 75mV across each emitter resistor @0.5 ohms. So I am really at 150 mA per device or 300mA per rail.
Andrew, thank you for that vbe multiplier formula, that is a keeper and now it makes complete sense to me.
I need an empty house to crank it up and see how it does at louder volumes!
Thank you Carlos for an interesting circuit and thank you Juan and willy for some great layouts.
Old 22nd January 2014, 09:26 AM   #1319
Originally Posted by cjkpkg View Post
.............................Andrew, thank you for that vbe multiplier formula, that is a keeper and now it makes complete sense to me....................
That is the basic to get you into the ballpark.
You now need to take account of the different Vbe in the 5 or 7 transistors to "design" the Vbe multiplier with it's resistors to take account of tolerances.
That is rarely done in this type of guesswork Thread.
regards Andrew T.
Old 22nd January 2014, 11:04 AM   #1320
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Attention, Atencion, Atenção, Achtung, Atento
Some problems found.
In one of the boards made (5 models made) you must be carefull about capacitance from the VAS colector to the ground...also be carefull about insulating the VAS colector to the heatsink as in two pcboards the heatsink can be connected to the ground through a screw.
The last Juan pcboards presented a problem related a capacitor in parallel with 47 ohms resistor.... this resistor is in the main VAS transistor (BD139) and it is connected to ground.... the capacitor in parallel should be removed.
The last Zimmer pcboards (white Brazilian ones) had a problem....the CCS that feeds the differential pair uses a BC556 and it is operating too much hot due to the current selected.... it is nearby the differential and the heat is being conducted through the copper tracks and heating, as a result, the differential pair that changes operational point and this results in floating and increasing in the off set voltage....the solution is to reduce the heat, so, the 68 ohms resistor that feeds and sets the current, in the VAS main series transistor emitter, should be increase to 220 ohms into this pcboard.
In other boards, if you feel the BC556 hot, or if you perceive drift in the off set adjusted while cold..then increase the resistor value from 68 to 220 ohms too....150 also works...also 120 works..depends on the board used and the distance, from the VAS (hot) to the differential pair...heat travells in the copper tracks and goes to the differential..the longest the best in this case to use copper tracks as heatsinks to cool down the BC556.
The replacement of this transistor with a BD140 with long leads also fixed the trouble..but become ugly and demand people to increase the lead hole diameter into the pcboard because the BD140 leads are thicker.
We have reached 275 units sold (stereo) and 6 guys reported troubles with heat in the output due to small heatsinks....i suggested them to increase heatsink or reduce power using only 8 and 4 ohms .... also a cooling fan was suggested to them.
One guy reported current drifting...then we reduce the differential VAS current ..we couple two differential together with a heatshrink tube and we detach the drivers from the main heatsink (hot one) and have used small individual heatsinks for them.
Some guys asked more bass to use as subwoofer..the amplifier is linear from 15 hertz up...but for them i suggested to increase the input condenser to 10uf/16 volts, positive to the base and the gain network capacitor increased to 220uf..this does not really increases bass.... just make them out of focus (alike) and reduces high end a little...but the psychological suggestion worked and they guy answered the bass was great...well.... mind has their own issues...we humans ... we are terrible to fool ourselves and to self convince ourselves depending our beliefs..
People are gratefull by the last DIY amplifier...some guys do not like heat like me..hey have reduce current to 100 mA each rail to use small heatsinks and to use a single pair in the output and only 8 ohms...other guys increased to 500 mA (one guy did that to keep coffee hot using heatsink as cup support).
About the Brazilian pcboard there are videos (in portuguese) about it in my youtube channel...my channel is not a paid channel..i am not a partner..there's no advertisement on my channel..i do want to keep my freedom...if they pay you have to respect copyrigth about songs..and they are so crazy that blocked my own song (my own song..composed by me and registered in my name and i am paid because of that)...so.... not a paid channel there:
http://www.youtube.com/user/destroyersoueu
In Facebook you have Dx amp too.
Also you have my own forum:
www.dxamp.com.br
regards and be happy,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Dx Blame ST together Dx Super AHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 10:53 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 03:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 02:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 11:26 AM
Copyright ©1999-2017 diyAudio
