Dx Blame ST together Dx Super A
Old 7th December 2013, 02:43 PM   #1301
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default How to check an amplifier pcboard
To know, in advance to connect power, if your assemble is correct.
https://www.youtube.com/watch?v=OA02klmMYaA
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 7th December 2013, 02:43 PM   #1302
Default Nice amplifier still4given
Remove C38 and it will sound even better.
regards,
Carlos
Old 7th December 2013, 02:46 PM   #1303
Default Juan Vargas pcboards for Dx Super A assembled, tested and approved!
https://www.youtube.com/watch?v=CEgK4l0MH8k
regards,
Carlos
Old 7th December 2013, 03:51 PM   #1304
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Thumbs up Caps removed
I watch the video and I was amaze that just a simple cap can make a difference wow ? I'm right now heating my hot iron to remove them thanks Carlos
by the way yes the leads space has to be update on the boards, I thought you will instal them this way as this image but is good that you saw the detail of the copper that is really close to the edge of the PCB "my bad"
ok caps off, sorry I was removing the caps while writing this jejejejeje
Best Regards
Juan
audio fanatic only
Old 7th December 2013, 04:19 PM   #1305
Default The empty spot, the C38 holes, can be filled
With a resistor...then use 6K8, or 8K2 or 10K or even 12K...then the emptyness will be filled.
regards,
Carlos
Old 11th January 2014, 10:07 PM   #1306
cjkpkg is offline cjkpkg  United States
Greetings,
I am etching boards as I type this for this amplifier. I understand now not to use the capacitor in position C38 - but should it be left empty or are you saying to put a resistor there?
Are there any other modifications that I should be aware of that folks have implemented?
Thank you!
Old 12th January 2014, 02:02 PM   #1307
Default You can left it empty
Some guys are not using high current in stand by mode...they are adjusting to 900 milivolts measured in the rail series resistor (10 ohms).
Some guys have small heatsinks and weak supplies....also some of themare not using Dx Supply to save room inside the enclosure and to save money.... these guys (30%) are adjusting to 90mA each rail at iddle.
regards,
Carlos
Old 18th January 2014, 10:26 PM   #1308
OK I took willy's TO-3 design and managed to get it to a transparency to make a photo etch board pair. This is the first time using positive pre-sensitized boards and I must say it is vastly superior to the old toner transfer method.
Progress so far...Just need to finish stuffing the boards, just the front end transistors and the jumpers, thats about it. I put the TO-3's in there for the photo op...I love me some TO-3 transistors.
Old 19th January 2014, 07:51 AM   #1309
Default Yes.... a more professional method..much better
toner is to make at home, to amateurs.... and forum is diy.... amateur forum...so...it is nice to the forum.....naturally other processes, more professional ones, results much better.
Congratulations...great job you did.
regards,
Carlos
Old 19th January 2014, 02:34 PM   #1310
they do look sexy diy PCB's
Juan
audio fanatic only
Dx Blame ST together Dx Super AHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 10:53 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 03:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 02:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 11:26 AM
