Dx Blame ST together Dx Super A
Old 1st November 2012, 12:29 AM   #101
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default I have reduced, original size was bigger
Each picture was 5 Megabytes.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 1st November 2012, 12:31 AM   #102
Default Last ones here
Enjoy.
Be happy,
Carlos
Old 1st November 2012, 09:11 AM   #103
Default It is not that ugly today
Here you can see the mess is under control.
regards,
Carlos
Old 1st November 2012, 09:45 PM   #104
Default Have you heard this one?.....no?... so i suggest you to listen
Install a good amplifier and good speakers, insert the plug into your PC output jack, cranck the volume all the way up and be enjoy:
Dx Super A - MKII - good sound with poor speaker - YouTube
regards,
Carlos
Old 1st November 2012, 10:53 PM   #105
lanchile is offline lanchile  United States
lanchile's Avatar
regards,
Carlos
I love those pictures, But I noticed you are using very "weak" power supply. how much capacitance are you using?
Old 1st November 2012, 11:09 PM   #106
Default Yes....my capacitor stock finished....i am using some old units
from audio systems i have dismantled..... aproximatelly 10 thousand plus 10 thousands...it is just reasonable....tolerable to operate 8 ohms..but i know some powerfull bass tones are "dirty" because of mains noise...for sure this is happening..as i do not use to listen loud, then it is not bothering me.
regards,
Carlos
Old 1st November 2012, 11:45 PM   #107
lanchile's Avatar
20000uf it is not so bad, I though those were like 1000uf caps. When I build some power supplies I do not use more than 40000uf per rail (under 100 watts RMS per channel). I try many values from 1000uf to 40000uf per rail in many amps from 50/80 watts RMS per channel at 8 ohms and I like it around 20000uf per rail better. Right now my 70 watts RMS at 8ohms diy amp, I am using 6800uf X 4 total for my power supply and I love it. I was going for 20000uf per rail but since I shoot for a "small" integrated amp I did not have enough space to use four 10000uf caps. Take a look.
Old 2nd November 2012, 06:10 AM   #108
Default Looking good your H/D amplifier
Thank you.
regards,
Carlos
Old 2nd November 2012, 10:10 PM   #109
Default Tweaking.... i love to do that.
Here you have a very fresh video..made 20 minutes ago:
Torture into the Dx Super A. - YouTube
regards,
Carlos
Old 2nd November 2012, 10:50 PM   #110
lanchile's Avatar
regards,
Carlos
Very nice carlos! What are the transistors on top for? are you running it at 50vdc?
Dx Blame ST together Dx Super AHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 10:53 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 03:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 02:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 11:26 AM
Copyright ©1999-2017 diyAudio
