Dx Blame ST together Dx Super A
Old 27th September 2013, 09:54 PM   #1061
Ranchu32 is offline Ranchu32  Australia
Originally Posted by still4given
I suppose if you run the Super A in A/B mode then it would. PMI sent me an email with values for parts that will allow it to run at higher voltages but I think the current is still limited to A/B operation.
Super A is Class AB, it is simply biased higher than most others.
Originally Posted by AndrewT
In all the above experiments you will find a significant improvement in PSRR if the low level stages are supplied with a ripple free supply, either a good regulator, or a good cap multiplier.
The improvement is so good that it supports the philosophy of builders of plain ordinary supplies for the output stage and only consider regulation for the voltage amplifier stages.
Are there are special considerations when adapting an existing circuit design to operate the IPS and VAS stages from a seperate, regulated supply, while the OPS continues to use simple bulk cap filtering?
Is it as simple as splitting the two rails and hooking the newly formed IPS/VAS rails into a regulated source? What is the consequence of the potential difference between the IPS/VAS and OPS rails? What does the grounding scheme look like?
If the improvement is as dramatic as you say (I don't doubt) then why don't we see more power amp supply boards with a low current regulated supply section. It would take up very little board space - an LM317 & 337, a few diodes and small passive components.
I generally take quite a long time to research my projects.
You seem to be very different in outlook.
The world might end tomorrow, let's bash on, there is no time to do any research. Damn the consequences.
I enjoy spending time researching topics of interest. I also enjoy spending time in the workshop building things: drilling, soldering, wiring (or working on cars, etc). Sometimes I spend a lot of time researching a design and never build it. Other times I'm in the mood to build something and those times investigating every last detail would detract from the enjoyment. You might regard that as impatience; I would disagree. I don't mind making mistakes, to me that is part of the experience.
Old 28th September 2013, 06:19 AM   #1062
dudaindc is offline dudaindc  United States
dudaindc's Avatar
Originally Posted by still4given View Post
Hi dudaindc,
I wish I had known about those. I have already ordered some from Ebay. Where are you located? It could take weeks for the others to arrive. I may opt to buy some from you as well.
Thanks, Terry
Hi Terry,
I am in the metro Washington DC area.
Please drop me a PM if you need anything.
Caps could be in your hands in 3 days via Priority Mail.
D
"All measurements are wrong! Thus, measurement is the art of handling errors."
Old 28th September 2013, 07:08 AM   #1063
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Heatsinks are good dear Terry
Voltage drop..... practical way without worry about what is voltage drop:
Take you multimeter and set it to read 20 volts DC or something alike..more than 10 volts.
One multimeter probe point goes to the series pass transistor colector
The other goes to the series pass transistor emitter
Adjust the rail trimpot to read 5 volts..... ready!
Do the same to the other rail, measuring other rail transistors and adjusting the other trimpot.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 28th September 2013, 07:19 AM   #1064
Default This regulator was made for you to save some money
because electrolitic capacitors are expensive.
This amplifier, when operating 2 ohms, and using the standard supply (rectifier and filters) will need 60 thousand plus 60 thousand microfarads.. this means you may need to use 24 capacitors of 5000uF.. the ones you can have by lower price.
Was the solution, as the standard price of capacitors use to be high...exception are the ones Duda found in Ebay and because of the low price he bougth a huge stock.
When you drive your power amplifier hard, draining huge current from your supply (full power at 2 ohms) the mains frequency or twice the mains frequency appear in the sound reproduction.... the way we have to be rid of that is capacitance multiplier or other kind of electronic filter.... to allow you to filter using much less capacitors.
You see that 24 capacitors uses a lot of space, or needs room to be installed...the electronic supply can be even smaller if you install vertical heatsinks in a blade style, this may save some internal space and the performance is better than single capacitors filtering...voltage is much more stable and mains noise is smaller.
Another advantage is that you will be rid of the current surge that happens when you switch the power on into a supply that uses 60 thousand plus 60 thousand microfarads..sometimes the current is so big that can burn your fuses...then you will have to use a current surge protection circuit...this creates one more pcboard, more circuit, relays, transistors and several other passive parts (see Rodd Elliot surge protection).
regards,
Carlos
Old 28th September 2013, 07:43 AM   #1065
Default Because of some high power amplifiers .....
Zimmer is working hard in a research to develop a SMPS good enough to feed high power amplifiers.
He is facing problems, as to provide kits, and pcboards, the stuff gonna be heavy (transformers, special heatsinks) and big in size.
Another big problem is that we cannot provide instructions for people to make the transformers themselves..... this ask for a lot of special skills, it is complicated and sometimes critical.... mistakes produces expensive parts fried.
Zimmer have already spent a lot of money doing it, several prototypes made....now a days things are becoming a little bit better.
We are trying to find solutions because some future amplifiers, as Dx Boom, Apocalypto, Troyan, DHR Turbo, Armagedon and MAKO demand huge supplies and the transformers will be so big that you will have troubles to handle... we are needing something smaller and lighweigth.
I personally do not appreciate SMPS, because of RFI or magnetic interference it generates that forces you to filter into the power amplifier reducing the bandwidth .... another solution is to shield into a magnetic case.... another thing i dislike is the speed to supply energy...we cannot use 20 thousand plus 20 thousand microfarads in the SMPS output because the current surge will make it shut down..... but we are searching for solutions.... Zimmer is burning fingers and i am helping a little, as i am not skilled about the stuff.
Another problems is that SMPS uses mains voltage rectified...this is dangerous..some beginners have the audacity to try themselves when they should be distant from the mains wires.
We cannot offer pcboards and schematics...people will not build the transformers....so..... we have several things to figure out a good solution.
In the reality we are in a big trouble... we need something like that because of high power amplifiers...we are not skilled... and we do not want to copy other supplies... we want to develop our...if gonna be alike or not this does not matter.....what matters is for us to know we are doing ourselves.
Maybe we will be forced to accept some voltage drop...or something not perfect into our point of view... we may have to say:
- it is quite good, not perfect, it is the best we could do
So, we may have to make concessions as we do not have all the needed skills to make a perfect one.
Well..... who knows?....maybe we will figure out the needed solutions.... this is what drive us.
regards,
Carlos
Old 29th September 2013, 02:29 PM   #1066
dudaindc's Avatar
Carlos, just for clarification I would offer the following.
The capacitors I am selling were NOT purchased on eBay, and were not purchased by me.
They were purchased in a large quantity by the company of a friend of mine through an authorized distributor.
These were intended for a project that was ultimately cancelled by my friend's customer before filing for Chapter 11.
These are being sold here and on eBay as I am trying (as best as I can) to help my friend to recover part of the money lost on this project.
I purchased a box (200 units) for myself and sold about 34 boxes so far. I believe he has about 15-20 boxes left.
One would have to purchased 10,000 units in order to pay the price asked for a single capacitor, so these are a good deal IMHO.
Back to the thread...
Cheers!
Old 29th September 2013, 02:33 PM   #1067
Default I see...thank you Duda
I am sorry....i may have offered a wrongidea about you.
regards,
Carlos
Old 29th September 2013, 03:51 PM   #1068
dudaindc's Avatar
regards,
Carlos
No problem at all Carlos.
I just want to avoid confusing my caps with fakes from eBay.
The first post on both threads (see my signature) tell a little about the origin of the caps.
Those are really nice looking boards...
Old 29th September 2013, 04:26 PM   #1069
Default So... it is all right
Thanks,
Carlos
Old 7th October 2013, 06:07 PM   #1070
Default We have a builder's thread, so, use it to show your progress
Post pictures, doubts, problems....everything you need...also about the Dx Supply
If you are buiding with pcboards from Juan or etched by yourself..then post there.
regards,
Carlos
Dx Blame ST together Dx Super AHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 10:53 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 03:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 02:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 11:26 AM
Copyright ©1999-2017 diyAudio
