Old 14th October 2012, 10:00 PM   #1
laemmle is offline laemmle  Canada
Default Dead Altec 9440a
Hello,
I'm new to the forum, I was about to post my question when the search window suggested a very helpful existing thread named:
"ALtec 9440A... suggestions?"
It's filled with helpful suggestions for an amp that sounded like it had promise, but my amp seems completely dead, out of the gate.
It has the modification of two mounted fans on the back. these work when plugged in individually but the outlets built in to the unit are dead.
the 10 Amp 250 fuse on the back of the unit looks to be good. It's harder to tell with the pigtailed fuses mounted on top of the transformer.
I guess my question is where do I even start?
I don't want to waste anyones time here.
Thank you very much for your attention and consideration.
Mike.
Old 14th October 2012, 10:17 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
pics will help
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 14th October 2012, 10:31 PM   #3
No problem at all. Is there something specific that you'd like to see pictures of?
Old 14th October 2012, 10:41 PM   #4
Zen Mod's Avatar
well , all details you can give
but - even from this pic I can see that you need skilled technician - for thorough cleaning , total recapping and check/repair
been there ......
I can check tomorrow ..... I think that I have schmtc
Old 14th October 2012, 10:50 PM   #5
Default schematic
Zen,
That would be very helpful. all I've managed to find on the internet were block diagrams. With a schematic I could approach a local technician I know.
I'm not opposed to putting in the cleaning work and the recapping but yeah I have a feeling that this one's a little over my head.
Mike
Old 14th October 2012, 11:16 PM   #6
Zen Mod's Avatar
here it is , service manual : https://dl.dropbox.com/u/20665608/ALTEC%209440.rar
it will be there for some time .....
Old 15th October 2012, 11:58 AM   #7
djk is offline djk
djk's Avatar
"these work when plugged in individually but the outlets built in to the unit are dead."
The 1.5A fuse on top of the transformer is blown.
"It's filled with helpful suggestions for an amp that sounded like it had promise, but my amp seems completely dead, out of the gate."
Nothing to do with the fan fuse.
This is a tough amp for most technicians, even with the complete service data.
Does the unit power up and the relay click, if now there is a problem.
If it does power up and the relay clicks, then you must use the 1/4" inputs, the XLRs will not work without the (optional) transformers being installed in the internal octal sockets.
Remove all solder from every connection (transistor end edge connector pin) involving a gold component lead and re-solder with 4% silver solder.
Candidates for the Darwin Award should not read this author.
Old 15th October 2012, 12:11 PM   #8
Zen Mod's Avatar
I worked on few , in last decade ; yup , complete cleaning , re-cap , resoldering, and repair
they're not for newbie , in any case
when repaired - workhorses for another 25 years
Old 15th October 2012, 07:36 PM   #9
Zen,
thanks so much for the manuals and docs.
djk,
I think what I'll try to do is your two suggestions here and see how far I get.
I AM a newbie for sure.
I want to thank you guys for taking the time. I really appreciate it.
Mike
ALtec 9440A... suggestions? Stormrider Solid State 21 20th August 2012 06:47 PM
Altec 9440A? Tyimo Solid State 22 2nd July 2012 07:05 PM
Altec 9440A how does it sound ? Larss Solid State 1 29th May 2012 07:13 PM
FS: Altec 9440A lassoharp Swap Meet 1 5th November 2009 12:51 AM
altec 9440A hiendaudio Solid State 0 18th April 2004 08:13 PM
Copyright ©1999-2013 diyAudio
