Pre-Amp distortion - diyAudio
Old 13th October 2012, 06:10 AM   #1
Jolida is offline Jolida  India
Default Pre-Amp distortion
I am getting a strange distortion from both channels of my pre-amp (Harman Kardon Signature 2.0). I had not been using it since more than a year now. When I recently started using it, I started getting a strange kind of distortion, as if the speaker cone is torn. The vocals sound torn especially with recordings of a high input level. I tried eliminating every piece of equipment & interconnect in the line-up & the problem lies with the preamp. Now it's getting worse, with the balance shifting a lot towards the left channel. The left channel sounds louder & brighter than the right. Please Suggest
Old 13th October 2012, 06:32 AM   #2
Sounds like dirty potentiometers but there's also a chance capacitors in the signal path or powersupply have worn. It would be worth looking into these first.
Negative Feedback: The Need for Speed
Old 13th October 2012, 06:38 AM   #3
It's a digital volume control. Will this still have a potentiometer inside? There is a big volume
Knob on the amp but it changes the volume digitally.
Old 13th October 2012, 06:54 AM   #4
It's not the knobs then, no mechanical volume / balance control What remains then would be a check-up on the important capacitors inside the amp. Are you familiar with working a bit on electronic circuits?
Old 13th October 2012, 06:56 AM   #5
jitter is offline jitter  Netherlands
jitter's Avatar
According to page 14 of the service manual of that amp, the volume control is electronic, i.e. the knob doesn't operate a conventional potentiometer.
I take it you tried every input on the preamp and get the same result on each input?
Since input selection and volume control seem all electronic in this device, I'd start with measuring if all voltages in the PSU are present and correct.
Old 13th October 2012, 06:59 AM   #6
Yes I'm quite ok at electronic stuff but not anywhere close like u guys
If u could please guide me as to what has to be looked at, I would really appreciate.
Old 13th October 2012, 07:03 AM   #7
Yes I have tried all inputs on the amp & the problem still remains
Old 13th October 2012, 07:08 AM   #8
I just peeked at the service manual as well and you'll have quite the number of components to check! Like jitter told, using the manual, knowing a bit about the used ICs, you could check up on all the voltages to see if they are proper; measure the supply output and if that is ok, measure the supply pins of various ICs throughout and if that looks okay, try to find any capacitors that may look like they're puffed up or leaking or otherwise show anomalies.
It's going to be quite the hunt.
Edit: Oh and forgot to mention another 'easy' checkup: Internal connectors gone bad (bad contact) so reseating those may also help.
Old 13th October 2012, 07:16 AM   #9
Great. I also have an Oscilloscope but have never learnt how to use it to debug such issues. Or a multimeter is just enough ?
Old 13th October 2012, 08:09 AM   #10
To measure supply voltages a multimeter is just fine. The scope starts to become useful when you also have a device to generate a test signal, often a sinus. Then, you just probe the signal path starting at the input all the way towards the output and see where the signal goes weird.
Large signal distortion in pre/VA stage Thoru Solid State 9 10th June 2011 01:12 PM
Carver HR 875 pre-out bass distortion poopydoopynoopy Solid State 3 25th May 2010 11:22 PM
Low Distortion High Dynamic Range Pre-amp Nico Ras Pass Labs 64 18th May 2007 05:26 AM
ultimate pre amp 113db S/N and distortion s almost 0. Is it better than Krell preamp diysmartdeep21 Chip Amps 32 14th February 2005 08:21 PM
Usable distortion analyser for Pre-/Amps MichaelB Solid State 22 1st February 2004 12:39 PM
Copyright 1999-2017 diyAudio
