Old 12th October 2012, 08:25 PM   #1
robmil is offline robmil  United Kingdom
Default Transformerless input for 150ohm mics ??
Hi all
I'm building a variation of this:
http://www.sg-acoustics.ch/analogue_...ariente_r1.pdf
but I'm using IC chips (LT1115) for the gain stages. The layout so far looks OK. I am on a budget so don't want to go down the input transformer route AT ALL.
Is it possisble to use a bunch of resistors and caps to get the same result as the transformer (going to use 48v phantom low impedance mics)? The transformer route is costly but I still want low noise levels, phase and frequency response using a passive/active version.
If anyone can help...point me in the right direction OR even better - has achieved what I am after PLEASE share )
regards
Rob.
Old 13th October 2012, 11:18 AM   #2
Read Jung and Whitlock and Self and Cordell.
Old 13th October 2012, 11:38 AM   #3
This might be of interest. Not much in the way of specification given, but perhaps if you follow up data on the chips referred to you'd get an idea.
eBay Australia: Buy new & used fashion, electronics & home d?r
You mentioned that you would be using powered microphones. You may well find that the self noise of the microphone's inbuilt preamplifiers will exceed the input noise of the preamplifier you follow them with.
Terry
Old 13th October 2012, 11:52 AM   #4
SY's Avatar
Your friends are THAT1510/1512 and SSM2019- look at their app notes. If you want to get all the way back into the capsule electronics, read Scott Wurcer's two part article in Linear Audio.
If there's a sucker born every minute, where do the rest of them come from?
Old 13th October 2012, 12:20 PM   #5
THAT Corporation Audio Technology Are you interested in balanced input and balanced output? THAT corp currently have the most advanced chips for transformerless balanced inputs and outputs and I suggest you have a good read of the literature on -
Preamplifier, THAT 1510 or 1512
Outsmarts bal line driver THAT 1646
InGenius bal line receivers THAT 1200, 1203 and 1206
Bill Whitlock, who Andrew mentioned, had a hand in the design of these devices. You can read his tutorials on the Jensen transformers site.
These devices are also discussed on the Picocompressor audio design forum.
Sorry if I seem to be mentioning one manufacturer to the exclusion of all the others, but they are currently the best products.
Keith
Old 13th October 2012, 01:03 PM   #6
EssB is offline EssB  United Kingdom
It makes no sense to build that design without the transformers. Use his other design:
http://www.sg-acoustics.ch/analogue_...eneroso_r1.pdf
There are similar transformerless in-amp based designs out there, I've lost all my links so you'll have to search for them. e.g.
- Greme Cohen, OM1556 - Phillips Australia 1984
- Anthony Tilbrook, AEM 6012 - 1987
- Neve design? Amek Mozart 9098
- Green mic pre.
Old 13th October 2012, 04:19 PM   #7
Tajzmaj is offline Tajzmaj  Slovenia
Amek M2500 is also good option. It sounds very good and it's really cheap to build. PM me if you ant p-cad pcb layout.
Cheers
Old 13th October 2012, 06:26 PM   #8
thanks all.
I quite like the Amek design and I think I can add phantom to it easily enough.
I might change those ZTX214s for 4403s or THAT300 transistors to make the layout easier - seems the way to go )
Essb..that design looks harder to layout but may well sound far better but will take me 3 weeks to lay the thing out
Rob
Old 13th October 2012, 06:43 PM   #9
I use BC550/560c and it's fine. And very cheap as well.
Cheers
Old 13th October 2012, 07:12 PM   #10
Rob
You can easily simplify it. I did a trial layout of my own version (2 channel) and it wasn't that bad. I've yet to built it though.
Of course, if If you keep simplifying it you end up with something like the Amek M2500 that Tajzmaj posted - they're all similar in-amp designs.
(Thanks Tajzmaj, I've added that one to my collection)
Correct way to hang mics stevegarcia Everything Else 10 27th April 2012 01:17 AM
New Edcor opt, what would a 150ohm primary be used for? athos56 Tubes / Valves 31 20th November 2010 06:56 PM
Elation mics bernification Everything Else 0 23rd July 2007 11:24 AM
Measurement mics bombardon73 Multi-Way 22 28th November 2004 01:56 PM
panasonic WM60AY Mics wintermute Swap Meet 0 4th December 2003 09:21 AM
Copyright ©1999-2013 diyAudio
