Cyrus One/Two volume pot... linear???
Old 12th October 2012, 01:18 PM   #1
bleachershane is offline bleachershane  Scotland
bleachershane's Avatar
Default Cyrus One/Two volume pot... linear???
After receiving yet another Cyrus amplifier to service and finding it had been mishandled by Parcelforce, I was heartbroken to find that the most damage had been taken by the volume pot... The customer is currently filing a claim with Parcelforce before I continue work on the amplifier.
The volume pots in these amplifiers are pretty darn rare. In fact the only way I've found to replace them (and keep the amplifier aesthetics as original) is to take one from another amplifier!
And this is what Parcelforce did...
So, 10KBX2
10K = Resistance
B = LINEAR?
X2 = Dual gang
Is this not a bit strange, using linear in a volume position? There seems to be no added circuit to make this linear pot logarithmic so why did Cyrus do this?
And if anyone knows a good way to replace the volume pot (balance completely not essential) and keep the original knob setup?
"If only we'd known that iPads would unite to enslave the people they entertained."
Old 12th October 2012, 02:12 PM   #2
Can you measure the vol pot, even just one track, to confirm it is linear or some audio type taper?
Set to 0, 270 and the geometric middle 135, rotations and measure the resistances.
A lin can be chosen because generally the track to track matching is better with dual lin.
That maintains correct balance as the vol pot is rotated.
There may be a log law faking resistor in there.
eg.
a 10k pot feeding an input with a 1k5 Rin value will give a sort of log law over the lower 3/4 of the rotation. The top 1/4 becomes a sort of S shape taper.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th October 2012, 03:56 PM   #3
Here is the measurements of the potentiometer taken whilst in circuit, this would show up any fake log resistors used (there are none that I can identify on the board itself)
Old 13th October 2012, 01:59 AM   #4
Ian Finch is offline Ian Finch  Australia
"B" taper was originally described as a double-end log. pot, pretty much as you measured.
I won't guess why it was done this way and the service manual doesn't specify the part but usually they found application in balance or Baxandall tone controls.
HiFi Engine has a readable service manual for Cyrus 1
Ian
Old 13th October 2012, 02:15 AM   #5
Double-end logarithmic pot? Now that's new to me, but makes sense in relation to the graph. Thanks for the answer... I wish they hadn't messed around with pot law codes so much!
Have all the service manuals, but as you found they didn't state the exact part specification.
I wish they hadn't used such a bloody awkward part to replace!
Old 13th October 2012, 02:52 AM   #6
Exactly! On reflection, I think the plan was to give the impression of LOTS more power available as the sound is subjectively loud quite early in turning up the volume. There is only so much you can do to impress buyers with a 25W amplifier!
My Cyrus 5 is not so quick to rise in volume but uses a flashy digital control so I guess that there, the law is coded in the (OEM?) chip.
If ever an "A" taper was available for such a complex assembly, I can't see why it wouldn't substitute if the owner agreed. It just means he uses more of the scale and gets finer adjustment. I've even replaced wafers in some unobtanium pot assemblies but that is just a labour of love, taking hours to complete and test.
Ian
Old 13th October 2012, 08:40 PM   #7
Your reply makes complete sense... Although perfectly powerful for me (I quite like the Cyrus One) I can see that they would've wanted to give an impression of more power being on tap with the slightly sly use of this type of pot... which I never knew existed!
In my own Cyrus I would rather replace this for something like an Alps Blue Velvet, the problem with that as you may know, is coupling the pot shaft with the knob in a Cyrus One/Two. Now, if I could find a reliable, reasonably simple way to do that, I would be a very, very happy man!
The customer is starting his claim with Parcelforce before I begin any further work. I have ONE solitude original volume pot in a Cyrus Two which I use as a donor for repairs...
Now, replacing the track wafer... interesting, but must be a bloody nightmare!
Still, work a few hours of experimenting!
Old 14th October 2012, 05:29 AM   #8
In my own Cyrus I would rather replace this for something like an Alps Blue Velvet, the problem with that as you may know, is coupling the pot shaft with the knob in a Cyrus One/Two. Now, if I could find a reliable, reasonably simple way to do that, I would be a very, very happy man!...
Don't despair, I have read a Cyrus 2 thread here about the ALPS RK27 transplant...seemed a good result but of course, you lose balance control....I'm searching again.
Ian
Old 14th October 2012, 06:43 AM   #9
Default ALPS transplant
Ah, here it is in a concise form as about the best result I saw. Kinda miss Sonusthree around here.
potentiometer for cyrus2
Ian
Cyrus One/Two volume pot... linear???Hide this!Advertise here!
Mission Cyrus One - Volume Help Needed Klaymen Solid State 0 30th November 2011 05:18 PM
Turn a log pot into a (kind of) linear pot osterchrisi Parts 4 12th October 2011 01:40 PM
single push volume pot, volume up/down via a button. dragonxwas Analogue Source 4 2nd June 2011 06:56 PM
linear pot east electronics Solid State 4 9th August 2008 01:34 PM
Volume control : - pot' or pot' variable feedback resistor (gain) ? ash_dac Solid State 5 1st August 2006 05:07 AM
Copyright ©1999-2017 diyAudio
