Old 10th October 2012, 07:37 PM   #1
Default can anyone explain this amplifier? Audio Telex 2sa500B
Hi
Just got a hand on a pair of these. dirt cheap.
Its for PA application but given the prodigous amount of heat sink, transistors TIPC (20 each amplifier) and a output coupling amplifier makes me wonder can it be modified to hifi or SQ use.
If we look at schematic it has two wings of single ended TIP35C coupled with an output transformer probably step up . so for hifi can we modify like swaping primary to secondary and increasing bias to sort of run it in class A????
It would be very intersting if any suggestion can be provided to make it a diy hifi.
File Type: pdf Audio-Telex-SA500B-Service-Information.pdf (216.0 KB, 19 views)
Old 10th October 2012, 07:45 PM   #2
here is the detailed schematic.
How does the audio output work in amplifiers?....can someone explain to me? Pls chipper Car Audio 12 17th May 2010 10:30 PM
Thule Audio's GND Management by Integrated Amplifier with RC - who can explain tiefbassuebertr Solid State 2 10th February 2010 09:03 PM
can anybody here explain this audio circuit ankan Chip Amps 5 29th April 2009 03:03 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
