♫♪--My little posh Tringlophone--♪♫ - Page 2 - diyAudio
Old 12th October 2012, 12:01 PM   #11
Bigun is offline Bigun  Canada
Bigun's Avatar
Elvee - very nice work, I really enjoy the line of designs you have put onto the forum, it pushes the thinking beyond the usual and doesn't rely on fancy components. This one is particularly interesting as it lends itself to a hybrid design with a valve based votlage amplifier stage.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 12th October 2012, 12:04 PM   #12
Bigun
you stole one of my thoughts
regards, Pawel
Old 12th October 2012, 05:52 PM   #13
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by padamiecki View Post
Elvee
did you try correction error input stage like for HP version?
??? Sorry, I don't see what you mean
Dear Elvee
I have at about 8 pcs old KD502 but no proper heatsink for them.
Is this possible to use modern TO247s?
Yes, TIP3055 or MJE3055 would be OK, as any similar transistor.
If you use faster devices, some corrections might be needed. So far, I only tried 2N3055's.
please post some pics, maybe pcb?
Pics, in a day or two, PCB nope
also asc file for tringlophone?
PLEASE!
Here is one version. Maybe not exactly identical to final graphic schematic, but enough to get you going and have some fun
Thanks, and yes, I think so. For the moment, the VAS does its job, but it is a little... bland shall we say. Alternatives are welcome
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 12th October 2012, 10:07 PM   #14
Bigun's Avatar
I wouldn't call anything here bland, this CFP input is very nice and perfectly suited to give good linearity, low output impedance and all keeping only local 'current' feedback
Tube input & VAS is fun and easy to do, there are lots of options available to pick from depending on what you want to achieve. You don't need a lot of gain, so a medium-mu tube would be good and if you want lowish impedance from the tube then you could choose a bottle with two triodes and use one as a cathode follower buffer. Lots of options.
Old 15th October 2012, 06:36 AM   #15
cross gain stage like in the file from attachment:
regards, Pawel
Old 15th October 2012, 08:01 AM   #16
Elvee
you have light peak at point A at 250kHz...
the current through R1 is hm, problematic...
regards, Pawel
Old 15th October 2012, 08:03 AM   #17
... and if AC=0 we got this...
the circuit needs modifications
but anyway I like it very much!
regards, Pawel
Old 15th October 2012, 04:41 PM   #18
Elvee's Avatar
I didn't use that gain stage because the output swing is a bit limited for a high power tringlotron.
For headphones, it doesn't matter: the power is ample enough.
Elvee
You are not supposed to look at point A.
It is an internal test point to be used solely by the designer.
The user may just look at the overall frequency response.
should have deleted that *$£* TP
What is problematic? The notch at ~10MHz?
It is caused by the slow OP transistors and the various additional degenerations combined with the error correction. At this frequency, the weak residual output signal becomes completely out of phase with the correction, hence the null.
Note that it is almost completely a simulation artifact: in reality, it is unlikely you could observe something that clear-cut.
You should indicate the source of your graphs, things would be clearer.
I think what you show is the PSRR, see below.
In that case, no modifications are needed: it is entirely intentional.
Unlike many SE-Class A amplifiers, the Tringlophone is designed to be used directly with a raw, moderate quality supply, and doesn't need a gyrator or regulator: the PSRR over the audio band is decent, and in addition a notch is located at 100Hz to increase the ripple immunity.
Here are some pics of my prototype:
Old 15th October 2012, 08:11 PM   #19
audiobard's Avatar
...And how do you like the sound?
Old 16th October 2012, 06:42 AM   #20
Elvee's Avatar
Sounds sweet and nice (do you really expect I'd say something else? Let's wait for other, independent opinions)
♫♪ My little cheap Circlophone© ♫♪ Elvee Solid State 1682 16th June 2017 02:59 AM
Posh SW8 drivers Burnedfingers Subwoofers 3 1st May 2011 09:02 PM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 12:47 PM
Copyright ©1999-2017 diyAudio
