capacitor in series protect speakers from getting damaged due to signal clipping
Old 10th October 2012, 07:56 PM   #11
kevinkr's Avatar
The OP didn't mention anything about a tweeter, I'm very literal and since he mentioned "subwoofer" I'm assuming that's what he meant and that this sub-woofer either has an integral amplifier or an external power amplifier. I suspect he is probably talking about a typical home theater speaker package. Hopefully he will clarify what he means.
The OP has not mentioned whether this is a reflex, acoustic reflex, horn or bandpass. I suspect based on limited experience that clipping will be less obvious with a bandpass box than the other types.
The issues I can think of are running out of xmax if the woofer power handling and box design result in insufficient power handling under the specific clipping situation, and potentially overheating the VC.
A limiter and/or compression ahead of the power amplifier has been a traditional way of handling these issues, but of course just turning the volume down a few dB could be helpful as well.
Hopefully the OP will tell us a bit more about drivers, box(es) and amplifiers used, and whether the issue is mainly LFE related or more generalized.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 10th October 2012, 08:02 PM   #12
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
A friend suggested me to use a small incandescent lamp in series with the tweeter. As power increases dangerously, lamp glows increasing its internal temperature, and then its resistance, limiting power at the tweeter coil.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 10th October 2012, 08:29 PM   #13
lanchile is offline lanchile  United States
lanchile's Avatar
Originally Posted by crunch123 View Post
Ok then, will reducing the treble frequencies make tweeter's safe ?
you can use one of these to protect tweeters. Jbl Sk3 Sk3 Fuse Lamp - 050=SK3 | Spectrum Audio
Old 10th October 2012, 11:53 PM   #14
cbdb is offline cbdb  Canada
Oh actually i do not have access to the tweeter's crossover circuitry. In fact its inside the speaker enclosure. However i can lower the treble frequencies through my graphic equalizer. Will this measure protect my tweeters ?
It will help but your music will be missing the high end. The above light fuse is what you need, but it has to match your tweeter (power).
capacitor in series protect speakers from getting damaged due to signal clippingHide this!Advertise here!
Signal limiting/clipping jason12 Analogue Source 2 20th February 2011 01:54 AM
AR M series Holographic speakers - capacitor question midside Multi-Way 2 24th January 2011 01:51 AM
Calculation of HPF due to output capacitor, with source connected to load? wwenze Everything Else 1 28th February 2010 04:12 AM
Kids ran amp well in clipping levels, audible damaged? Techz Chip Amps 1 15th March 2008 10:09 PM
Hard clipping a guitar signal Skankadellic Instruments and Amps 4 22nd January 2004 03:29 AM
Copyright ©1999-2017 diyAudio
