diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Replacment for IRF064N (http://www.diyaudio.com/forums/solid-state/221304-replacment-irf064n.html)
muddasirwaheedmalik 10th October 2012 03:54 PM
Hi i need to replace IRF064N.
its rated 110A 55V used in car amplifier but Pd=200W. and pulsed current 390A
But these are not available here and i have replacement for
IXFX52N60Q2
It has high VDss=600v, Id=52A Ipulsed=208A but Pd=700W can it be used as i assume that IRFP064N would not be using that much current as it is connected in pull push 2 pairs for an amplifier for 400W into 4 ohmd i.e. around 10A output so i assume input current would be no more than 15A conitinous olr 30A for pulsed. NB the mosfets are used in primary side of switching on 12V rails.
regards
Copyright 1999-2017 diyAudio
