Old 9th October 2012, 03:24 PM   #1
Default Low Power Design Suggestion?
I'm looking to replace the mid-high amp in my computer speaker setup (2.1), and thought it might be a good opportunity to try something solid state for the first time. It doesn't necessarily need to be simple, all I need is a schematic that I won't have to "complete" myself, since I'm completely new to SS.
I have a +13V DC power supply, 4 ohm speakers and would like an output power between 4W and 10W. Frequency response need not go below 200 - 250 Hz, but I should be capable of figuring out the filtering for that.
The original amp is a TDA8511J, and I'm considering using an LM4940, but thought I would check into SS for a change.
Any suggestions?
Tyler
Old 9th October 2012, 06:11 PM   #2
13V DC will give you about 4 W into 4 ohms and your in car amplifier
territory. Car amplifiers generally use unusual (compared to hifi) output
topologies to get good output voltage swing close to each rail, a typical
hifi amp might only swing to 2V below each rail, 9V versus 13V is a lot.
If you want more power you need a bridged arrangement and that
gets quite complicated in discrete SS for such a simple application.
Chip-amps rule at this sort of supply voltage and power, I think
going for discrete SS is asking for far more trouble than its worth.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 9th October 2012, 07:12 PM   #3
9V output will give you 20W peak at 4ohm.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC).
Vivaldi8 speakers
Old 10th October 2012, 03:52 PM   #4
Thanks for the replies. After more research, I've decided maybe I would like to build a bigger power supply and an F2J.
Tyler
DIY Max Power Low Cost Amplifier Design simon7000 Solid State 48 23rd May 2012 08:55 PM
Class A low power (5-10w) amp suggestion needed s3tup Solid State 42 13th April 2010 06:45 PM
Possible to design a high-power class D amp with a low output impedance? 454Casull Class D 2 23rd February 2009 07:33 PM
Low Voltage (+70V) Power Supply Design mwl6m Power Supplies 43 1st August 2007 01:00 PM
Cheap low power design for computer speakers haut Solid State 2 5th March 2004 04:47 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
