Need help with 60hz hum/ground loop. Schematic attached.
Old 10th October 2012, 09:17 PM   #21
Fusion916 is offline Fusion916  United States
Well I figured out what was going on with the hum even after removing the opamp. In my 2 transistor current mirror my output transistor (Q4 in your schematic) was going into thermal runaway or something as the current would mirror within about 10% of the diode connected device then would rail off into high current as the device heated up, knocking my voltage regulator out of regulation and sending 60hz to the speaker.
I instead used remitter resistors in my current mirror (47ohm) and adjusted the bias resistor to get about ~400mA Ibias and now the bias current stays rock solid even after the device heats up. The hum is completely eliminated.
Question about your schematic however. Do you split R1 and R2 to provide a signal ground? Is only the input stage required to be referenced to signal ground?
Old 10th October 2012, 09:35 PM   #22
forgot to ask, does anyone know where I can get spice models for the BC517 and the NTE261?
Old 10th October 2012, 10:46 PM   #23
cbdb is offline cbdb  Canada
No, The cap and those resistors form a low pass filter and are there to isolate the amp input from the negative rail. Although that may also act as an input filter.
Old 10th October 2012, 10:47 PM   #24
search this forum for "spice models"
Old 10th October 2012, 11:47 PM   #25
Isnt isolating the amp from the negative rail the same thing as providing an ac ground for the input source?
Old 11th October 2012, 07:32 AM   #26
Mooly's Avatar
Great to hear you have solved it, and I think others have answered your question
So yes, the cap that decouples R1 and R2 must be large enough such that no audio is developed across it. In practice we use very large values for the cap such that it shunts away any ripple on the bias voltage.
I would say that for a simple amp like this standard spice models should be fine.
Old 11th October 2012, 08:11 AM   #27
Mooly's Avatar
Actually I was really surprised at the high level of ripple that spice shows for this type of circuit. If anyones interested here is the file with ripple on the rails. I've probably made the amplitude unrealistically high but even at lower levels there is a big problem. Not sure why it simulates like this as you mention it is now silent...
Old 11th October 2012, 08:31 AM   #28
epicyclic is offline epicyclic  United Kingdom
He is using what looks like 6600uF ? on each supply rail and we dont know what voltage his regs are dropping as we dont know the transformer specs ( to calculate equivalent series resistance )............however it is only half wave rectified !!!!! so i am mostly with you Mooly.
Old 11th October 2012, 05:08 PM   #29
I'm not sure what the big deal of half wave rectified is your caps are big enough. As long as vripple is small there should be no ripple at the output of your regulator. And I'm using 3 6800uf caps per rail.
Old 11th October 2012, 06:25 PM   #30
Mooly's Avatar
Its no big deal if you design for using half wave and get the result you want.
Full wave is more efficent and the higher frequency ripple component and harmonics are easier to remove.
Need help with 60hz hum/ground loop. Schematic attached.Hide this!Advertise here!
Single Device - Ground Loop hum redjr Everything Else 12 27th April 2012 12:39 AM
Ground loop isolation to get rid of hum? Peter Pan Music 24 22nd May 2011 10:29 AM
Intercomponent ground loop hum pforeman Tubes / Valves 15 4th November 2009 02:24 PM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 06:46 PM
Ground loop hum jag Pass Labs 20 25th November 2002 05:32 PM
