I just designed an amplifier to power big speakers with small voltage! - diyAudio
Old 8th October 2012, 04:42 PM   #1
Default I just designed an amplifier to power big speakers with small voltage!
made out of one transistor and one single resistor I am able to get a lot of bass out of two double A batteries and it sounds really clear too! in between the two batteries wired in series I have placed a resistor between two wires and now it's super loud and clear too! almost perfectly clear bass from a 12" subwoofer!
plus a little bit of subwoofer movement as well!!! (perfectly visable cone movement!) it hits down to easily 4hz! and its really powerful too! with only just two double A batteries and they're probably half dead anyways! (found one battery lying outside and picked it up off the ground)
it sounds like at least 2 watts or more cause it's pretty loud and really clear and its pumping out bass like crazy! together the batteries only get like 3 volts or less because they're probably half dead (who knows) and they're still bumping like crazy! and really clear too!
I would call it the most efficent amplifier but of course there's always something better
I modified my original amplifier design and changed where the resistor was and now it easily bumps my subwoofer pretty loud! I'm gonna have to take some screenshots sometime and post them so you can see what I've come up with
edit! I changed my circuit just a tiny bit and I've got a 5 volt 800mA usb power supply powering my amplifier. and I've changed the resistors around again and now I'm getting maybe 15-20 watts out of this amplifier!! It's insanely powerful!!
I'll upload a screenshot soon to show you how it is set up!
Old 8th October 2012, 05:48 PM   #2
jan.didden's Avatar
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 8th October 2012, 05:54 PM   #3
jmillerdoc's Avatar
Can we see a schematic?
Old 8th October 2012, 05:57 PM   #4
DF96 is offline DF96  England
Nobel prize for free energy? (Or a Darwin Award?)
Old 8th October 2012, 06:06 PM   #5
Mooly's Avatar
This was your original amp I think,
I finally made a good working transistor amplifier
If you can post pictures of the new one and describe the connections we'll try and see what you have come up with
Old 8th October 2012, 06:09 PM   #6
jkuetemann's Avatar
Download LT Spice and draw us up a schematic so we can really see what you are up to.
---Jason Kuetemann---
Power is only granted to those willing to lower themselves enough to pick it up.
Old 8th October 2012, 06:11 PM   #7
Okay just give me a minute I'll post it soon!
edit: How do I draw the transistor in the software?
Old 9th October 2012, 02:58 AM   #8
Learning to use simulation software is great idea and eventually, we will all need to use software to draft, prove and analyse our experiments. However, this takes time to learn and then to post here.
Assuming you have a scanner available, why not neatly draw your schematic with a felt pen and attach the image to your next post. That will be a lot quicker until you get up to speed with any drafting/Spice program.
Ian
Old 9th October 2012, 04:25 AM   #9
well. the voltage will hold back the power. you may have 4V at the output maybe. that is 2W peak at 8ohm. 4W peak at 4ohm.
Old 9th October 2012, 10:21 AM   #10
Those pic's look like UFO shots...The truth is out there...
A small, low-voltage, battery operated amplifier Elvee Headphone Systems 29 6th November 2012 06:13 PM
Big bass from small power johnr66 Subwoofers 6 5th March 2010 03:40 PM
Amplifier to Drive small speakers haseeb Multi-Way 7 30th April 2008 04:24 PM
OB big sonding small speakers inrank Multi-Way 0 23rd July 2006 06:34 PM
Small BIG power for not so high-end class D diy’s Joep Zonnebloem Class D 29 29th April 2005 04:39 PM
Copyright ©1999-2017 diyAudio
