I just designed an amplifier to power big speakers with small voltage! - Page 10 - diyAudio
Old 18th October 2012, 04:41 PM   #91
sorry I was talking about a simple 5 volt 800mA DC adapter i never even mentioned wall sockets.. sorry for the confusion.
Old 18th October 2012, 05:30 PM   #92
Something like this one maybe?
Ian
Old 18th October 2012, 06:34 PM   #93
DF96 is offline DF96  England
Originally Posted by sofaspud
Here's a spoonful.
Are you sure the diagram matches the text? The emitter decoupler C3 should be omitted; it is not mentioned in the text. The text is a bit confusing about calculating coupling capacitor values. At the input it uses R1 instead of R1 in parallel with R2, and at the output it uses R3 instead of R3 in series with the output load (whatever that is). He assumes a beta of 10, which seems a bit low.
Perhaps this was in the introductory part of the book, so details were skipped over, but it could create as much confusion as it solves if people regard it as definitive.
Old 18th October 2012, 06:38 PM   #94
expert in tautology
bear's Avatar
Well, he said he was 15, but I suspect more like 11, 12 yo... just speculating.
By the time I was 15 I had built several Heathkits, including an SB-301 ham band SSB receiver, as well as duplicating a 6146 screen modulated transmitter (novice power, back in the day) from the ARRL handbook by myself.
My first scratch electronic project was a discrete transistor schmitt trigger that my father brought home the part for from an engineer at RCA in NJ where he worked at the time. It did not work. The engineer had made an error in the schematic. I used the Heathkit VTVM that I built to test its action. That was when I was 13, iirc.
But I suppose I had a natural talent for "stuff" so that helps.
I found a local ham who became my mentor, and he gave me my Novice test on his dining room table. He gave me all sorts of help, explanations and parts to complete the transmitter. Also, a ton of back issues of Electronics World, Popular Electronics and QST to read. Learning by doing and absorption.
Everyone is different, but that's how it went for me...
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 18th October 2012, 06:46 PM   #95
jmillerdoc's Avatar
No Cal, we are warning a 15y/o newbie NOT to mess with mains or even consider it....Other than that, I don't think it has been mentioned...
Cheers!
Old 18th October 2012, 07:14 PM   #96
okay I found a bunch more capacitors and I upped the total rating of them all combined to 7200uF's!!
that's quite a bit..
It sure made a big difference!! my subwoofer is causing a mini earthquake! and the low frequencies get down to like 2-4hz!
Old 18th October 2012, 08:08 PM   #97
expert in tautology
bear's Avatar
Ok, now my opinion is changed.
I think we have a troll who is playing us...
_-_-bear
_-_-bear
Old 18th October 2012, 08:11 PM   #98
Speakerholic
Cal Weldon's Avatar
I am aware of that. It was just a 'gentle' reminder from
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 18th October 2012, 08:28 PM   #99
Originally Posted by Cal Weldon View Post
Direct mains powered equipment discussion is not allowed here.
If this route is being considered, the thread will be closed
and your posting privileges revoked.
It's that serious.
Not the issue under discussion. Wall wart powered is OK for a newbie.
Mains powered is not IMO until some proper understanding is exhibited.
Direct mains powered was not mentioned, don't give people ideas ...
rgds, sreten.
Old 18th October 2012, 08:41 PM   #100
Please stop spouting nonsense about your build.
Realise you have no idea what the output bias point is, the input impedance is,
the frequency response is, the output power is (very low), and that you could
build something far better if you took any of the sensible advice available.
Your speaker can do nothing like 2 to 4Hz at any useful level.
How to build a decent speaker that works properly is another can of worms
you no doubt also want to pretend you don't need to know, but you do.
rgds, sreten.
A small, low-voltage, battery operated amplifier Elvee Headphone Systems 29 6th November 2012 07:13 PM
Big bass from small power johnr66 Subwoofers 6 5th March 2010 04:40 PM
Amplifier to Drive small speakers haseeb Multi-Way 7 30th April 2008 05:24 PM
OB big sonding small speakers inrank Multi-Way 0 23rd July 2006 07:34 PM
Small BIG power for not so high-end class D diy’s Joep Zonnebloem Class D 29 29th April 2005 05:39 PM
Copyright ©1999-2017 diyAudio
