I just designed an amplifier to power big speakers with small voltage!
Old 9th October 2012, 08:34 PM   #11
realflow100 is offline realflow100  United States
ok i think it will be easier if i just type out how I have it wired up instead XD since I don't have any felt pens lying around XD
ok positive power wire goes to positive speaker wire then a resistor goes between that point and the positive input wire
and the positive input wire has a capacitor in between it to remove DC from flowing backwards to the computer.
and the positive input wire goes to the transistor's 1'st lead
then the 3rd lead of the transistor goes to the negative input wire and the negative input wire also goes to the negative power wire
and the negative speaker wire goes to the middle transistor lead
I think that's it I hope I didn't forget anything!
by the way I have no clue what a UFO shot is
and my speaker is only being powered literally by a 5 volt 800mA charger cord and it shakes my desk and my computer around because it's so loud and has so much bass!! and it doesn't even get hot!!!
if I gave it 12 volts I don't know what would happen!!
Old 9th October 2012, 08:49 PM   #12
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Don't, please don't! I read just this same description about this doomsday machine
You'll blow up the earth, for Pete's sake! Don't! Don't !
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 9th October 2012, 09:03 PM   #13
willysan is offline willysan  Argentina
I can't wait to see the schematic!!
The first, second and third transistor's leads go somewhere but we don't know whether it is the base, the collector or the emitter. We have six posibilities and don't tell me some of them are impossible because this amplifier defies the laws of electronics.
Old 9th October 2012, 09:25 PM   #14
wahab is offline wahab  Algeria
Must be someting like this....
Old 9th October 2012, 09:31 PM   #15
CharlieLaub is online now CharlieLaub  United States
Do you work at LIRPA Labs?
Old 9th October 2012, 09:35 PM   #16
That's the secret!! LIRPA Labs did it again.
Old 10th October 2012, 06:50 AM   #17
Mooly's Avatar
The mk2 version. And it works... sort of. (we think the transistors a darlington if I remember correctly)
realflow100, there is one fundamental difference between this amp and your first. Can you see what it is ?
Old 10th October 2012, 08:49 AM   #18
jan.didden's Avatar
You guys are playing with the future of mankind
jan
Old 10th October 2012, 01:56 PM   #19
Mooly's Avatar
jan
Scary isn't it
Old 10th October 2012, 02:26 PM   #20
jam is offline jam  United States
jam's Avatar
Jan,
I did not know that you also had a sense of humor..............
Jam
P.S. Great issue from Linear Audio.
I just designed an amplifier to power big speakers with small voltage!Hide this!Advertise here!
A small, low-voltage, battery operated amplifier Elvee Headphone Systems 29 6th November 2012 06:13 PM
Big bass from small power johnr66 Subwoofers 6 5th March 2010 03:40 PM
Amplifier to Drive small speakers haseeb Multi-Way 7 30th April 2008 04:24 PM
OB big sonding small speakers inrank Multi-Way 0 23rd July 2006 06:34 PM
Small BIG power for not so high-end class D diy’s Joep Zonnebloem Class D 29 29th April 2005 04:39 PM
Copyright ©1999-2017 diyAudio
