Old 7th October 2012, 07:29 AM   #1
Default Power module for class A single ended amplifier
hi,
I have a pair of these power modules, i know these are for industrial power use rated for 500A Ic and 2500Pd . i know it would be non linear in characteristic curves BUT can i use it say for 10A conitnous IC for 60V supply via a 8 ohm resistive load or current drain Power mosfet so i will get around 100W single ended class A amp.
The module is ID500A-030 by mitsubishi. Please note that i already have a spare pair of these with some serious heat sinks and swithcing mode power supply available. regards
Old 7th October 2012, 08:28 AM   #2
here is the pdf file for the module
Old 7th October 2012, 01:30 PM   #3
djk is offline djk
djk's Avatar
The SOA on that part for linear use is horrible, 150W at 30V.
The $2 MJ15015 is better, it has 180W SOA at 60V.
The $3 MJ21194 has 250W SOA at 60V, and is faster than the MJ15015.
I have about 600 pcs of 2N6274 that are equally horrible for linear use. Rated at 50A and 30Mhz they have about 30W SOA at 30V. This part was about $40 (30 years ago) as an MRO part, and is about $300 today for mil-qualified use (we use these at work). At $300 each, 600 pcs of these would theoretically be worth $180,000. I made a big mistake when I bought them for $1 each. I saw this part in a cheap 12V power supply used as a pass transistor, that's about all they're good for.
Candidates for the Darwin Award should not read this author.
5W Single Ended Class A Power Amp From Mark Houston SSDIY Solid State 61 17th May 2013 09:50 PM
NP's first Single-Ended Class A amplifier using BjT's biased by a CCS tiefbassuebertr Pass Labs 15 27th March 2011 01:40 AM
813 RCA amplifier - 25w, class A1, single ended,2 tubes,Rout~1ohm audiodesign Tubes / Valves 5 19th September 2010 07:34 PM
Power supply for Single Ended Amplifier kmtang Tubes / Valves 20 27th June 2005 03:46 PM
High Power Single Ended Amplifier Club Unison845 Tubes / Valves 4 27th April 2004 01:32 PM
Copyright ©1999-2013 diyAudio
