diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   400Watt PA "SAFARI" (http://www.diyaudio.com/forums/solid-state/221070-400watt-pa-safari.html)
Riff 7th October 2012 12:23 AM
400Watt PA "SAFARI"
how to increase power from this amp.
Can I get a 500watt of these pa by replacing the final transistor using 2sc5200/2sa1943 x4?
Riff 7th October 2012 12:25 AM
1 Attachment(s)
Attachment 305053
moschfet 7th October 2012 12:40 AM
It is not so easy as it seems.
No!
Riff 7th October 2012 12:50 AM
Originally Posted by moschfet (http://www.diyaudio.com/forums/showthread.php?p=3192293#post3192293)
No!
what are you suggestion?
jaycee 7th October 2012 02:42 AM
That circuit is awful. If you want 500W for PA, you really want something rugged with 5x MJ15003/4 or MJ15024/5 with MJE15032/3 driver transistors. It will have to run reliably on 80V supplies.
You can use 2n5551 for inputstage, mje340/350 for vas. You will need a big heatsink, maybe fan cooled. After all that, you may find it was cheaper to buy a readymade PA amp. Maybe if you can get a scrapped one for the case and heatsinks it is worth it.
Riff 7th October 2012 03:07 AM
Originally Posted by jaycee (http://www.diyaudio.com/forums/showthread.php?p=3192371#post3192371)
MJ15003/4 or MJ15024/5 is too expensive on my local market...so how if i use 2sc5200/2sa1943 x5?
I've tried the sircuit using 2SC5200/2SA1943 x4 and given the supply 75vdc...for test load 4R 15"+12" device...
Riff 7th October 2012 03:10 AM
i mean MJ15003/4 or MJ15024/5 is hard to find and even if there is very expensive on my local market,
JOHN BALI 7th October 2012 02:09 PM
Hi Riff
This circuit maybe can stand higher voltage if we change some part value...
I'm also curious which one should be changed or how to modified this circuit???
maybe add VBE TR, add TEF etc.
So someone please give suggestion, which component should be changed to
stand up to +/- 70VDC & the power transistor will be 2SC5200/2SA1943.
Please tell us how many output pairs should be use?
djk 7th October 2012 02:10 PM
That amplifier will be about 60W/8Ω on a typical 40V supply.
Whoever labeled it 400W was demented/on drugs, etc.
moschfet 7th October 2012 02:23 PM
Yes, with an 8 ohm sense resistor. At a speaker, it is probably a bit more:
80-90Watt :D
But 400Watt I also can not see...
Copyright 1999-2017 diyAudio
