Old 6th October 2012, 01:13 PM   #1
Default Precision Acoustix 250
Hi everyone,
I have the opportunity to buy two Precision Acoustix 250 monoblocks.
They were built locally in South Africa, and very, very little information is available about them.
One of the monoblocks distorts slightly (unfortunately the seller is in another town, so I can't listen), and the seller claims that a resistors looks slightly blackened.
The price seems pretty good, but before I commit to buying, I'd like to get some input on fixing it.
I have attached the two pictures he has provided. I have asked for a close up of the main PCBs and will post them once I receive...
Any comments on the design, repair, potential specifications, etc would be much appreciated.
Thanks,
Chris
Old 6th October 2012, 01:22 PM   #2
Close ups of the main PCBs attached.
What kind of design is used? Specifications?
How easy would it be to diagnose and solve this problem?
Thanks guys.
Old 6th October 2012, 02:23 PM   #3
Complementary paired Mosfet output stage.
Around 150W or so 8 ohm, 200W or so 4 ohm.
You might be able to fix it by comparing the two channels and swapping components.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 6th October 2012, 02:25 PM   #4
Hi streten,
Thanks for the response!
I'm hoping that the fix is easy.
I think I'm going to pull the trigger on this
Chris
Old 6th October 2012, 08:14 PM   #5
they will be easy to fix. I have the circuit diagram for you and can also show you how to mod them to sound much better.
you can buy them with confidence.
Old 6th October 2012, 08:20 PM   #6
Thanks Rudi!
Much appreciated I'll chat to you soon.
Chris
Old 10th December 2012, 11:21 AM   #7
Hi all,
I'm still struggling with these.
I've replaced all of the small signal transistors (BC546 and BC556) on the left and side of the board, as well as the input stage transistors (is that correct?) which are BF470 and BF469.
No luck. Same distortion. I've looked at one monoblock vs another and they look identical. The only difference is the output MOSFETS, which seem to have been replaced on the new monoblock. The current output MOSFETS test fine.
Any ideas?
Chris
Old 10th December 2012, 11:48 AM   #8
Tried using the MOSFETs from the working amp in the broken one... no luck.
Old 10th December 2012, 12:10 PM   #9
sakis is online now sakis  Greece
sakis's Avatar
obviously .... replacing outputs that already work from one amplifier to another will not change anything ...... transistors is like a car wheel either working or not
keep the transistors as was ...check soldering recap the all unit ....
expect any of the small transistors to have some small leak
but 99% of the cases is some of the small capacitors doing the trick
Kind regards
sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 10th December 2012, 12:45 PM   #10
Electrolytics first?
Precision devices...... Village Plank Multi-Way 10 14th December 2008 07:49 PM
precision fidelity chevy_lvu Solid State 0 26th March 2008 07:42 AM
Precision Devices tinitus Multi-Way 1 8th January 2008 12:57 AM
Precision resistors carlmart Chip Amps 27 3rd March 2006 09:25 PM
Precision devices KevinTams Subwoofers 111 22nd December 2005 02:41 PM
Page generated in 0.11127 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
