LME49830+LatFET, yet another for design review LME49830+LatFET, yet another for design review - Page 2 - diyAudio
Old 6th October 2012, 09:25 PM   #11
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Hi Rick,
You are welcome. Will you consider output coil//resistor? Are you going to match the MOSFETs?
Panson
Old 7th October 2012, 02:00 AM   #12
rsavas is offline rsavas  Canada
Hi Panson,
Yes I will consider coil/resistor but it will not be put on the PCB, no room unless I make the PCB a slightly bigger.
Do you consider these Lateral FETs to be any better, sound quality wise, than the General Purpose IRFP devices?
Rick
Old 7th October 2012, 08:02 AM   #13
panson_hk's Avatar
Hi Rick,
I don't know much about this MOSFET. Is it only available from Farnell? I am looking forward to evaluating it.
The PCB house (www.batchpcb.com) you ordered PCB seems to be very inexpensive.
Panson
Old 7th October 2012, 11:45 AM   #14
Hi Panson,
Yes, it seems that Farnell is the only one that I can find stocking these FET parts? They show limited qty's available.
I have not used (www.batchpcb.com) yet. We shall see. Limited in capabilities, but for prototypes, they are the ticket.
Rick
Old 7th October 2012, 02:00 PM   #15
mj777 is offline mj777  Australia
I will be following this thread, I'm also interested with this kind of amp and will try to build if there is available pcb.
regards,
mj777
Old 18th February 2013, 12:36 PM   #16
QUANTORIX is offline QUANTORIX  Europe
Hi rsavas,
I'm interested in your research........
Project stopped or going on this year?
Please inform us about actual status.
Harry
Keep it simple - no valves - no ecaps
Old 18th February 2013, 12:45 PM   #17
Hi Harry,
Thanks for asking, it is going slowly but I am moving along. Lots of design/layout work done so far. Yesterday I finished design/layout of the AC input assembly. I neede a soft-start for the big transformer (used from a Pioneer SX-1250) Ordered parts from Newark, they had the ALFET Latfets on sale, so will keep posting as I go.
Rick
Old 18th February 2013, 12:45 PM   #18
scholl is offline scholl  United States
Default Is this an improvement?
Are these types of designs an improvement over the many used MOSFET amps available for $100-200 USD?
Old 18th February 2013, 01:02 PM   #19
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Looks nice -- with the non-inverted mode consider using an Elna silk (audio) capacitor -- available from DK.
Bob Cordell showed a design with an OPA2604 as buffer, inverter to the "-" input. I've done this with the LM4702 and lateral mosfets and the results are really nice -- and you can omit the input coupling cap. You can easily add it onto the design at a later date once you've completed the original.
Lateral mosfets are wonderful sounding devices.
Old 18th February 2013, 01:33 PM   #20
regal is offline regal  United States
es the biggest being perfect phase inversion so that a complimentary mosfet isn't require, these never match so this design should be about the lowet in THD in a lateral mosfet output possible.
If you order PCB's and need a groupto go in for lower cost let us know.
LME49830+LatFET, yet another for design reviewHide this!Advertise here!
LatFET OPS. Neutrality Solid State 21 17th May 2013 06:21 PM
LT1166+LME49830 design by Bob Cordell. Headbanger Chip Amps 6 6th October 2012 04:59 PM
LME49830 PCB design berni8k Chip Amps 14 20th July 2009 04:45 PM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
Hi/Review Design Sch3mat1c Tubes / Valves 37 29th January 2003 02:30 PM
Copyright 1999-2017 diyAudio
