Old 13th October 2012, 11:28 AM   #81
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
if nothing else , using those mosfets for T8 and T9 CCS-es is waste
simple Wilson two bjt CCS for T8 position , mirrored to T9 position, is better solution , freq. wise and dyn. imp. wise
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 13th October 2012, 04:44 PM   #82
donpetru's Avatar
Originally Posted by AndrewT View Post
I would throw away T7 & T8 & T9 and go back to a BJT CCS and a BJT mirror.
I'm not saying your recommendations are not good but not targeting recommendations to this topic, to create an audio amplifier with only MOSFET and/or JFET transistors.
Speaking of the latest version of CCS, not bad to be taken into account next CSS topology. Look at the attached image below.
Old 13th October 2012, 04:55 PM   #83
Zen Mod's Avatar
your choice ;that's the same as you said that you want to make entire car wheel from steel
use whatever part , but best for position/role
which one - left (cascoded Jfet , depletion mode biasing ) , or right one (bjt+mosfet,enhanced mode biasing) ?
Old 13th October 2012, 05:12 PM   #84
donpetru's Avatar
Your comparison above is totally wrong.
This project it's just a theoretical exercise that would follow a practical approach. Must demonstrate that it can. What will get, remains to be seen.
I mean of both CSS, from the right and left image posted above. Is just one example.
Old 13th October 2012, 05:27 PM   #85
Hello
Actually I want to build these amplifier from all fet. Otherwise it will be just another amplifier....
After I test it we can always change to get better performance in case it will be a need.
Yes I want a good (or great) performance IT WOULD no reason to DIY!
For that reason I do not reject any idea specially when a few guys advise the same think!
Zen Mod
These how you tought to use BJT for T8 & T9?
Please let me know.
Thank you
Greetings Gabor
Old 13th October 2012, 05:36 PM   #86
The amplifier can be all fet.
The CCSs are just sources and sinks for the current flows to/from the rails. they can be BJT and the amp is still all fet. At least that's my view.
If you don't afree then use jFETs wired as CCSs. You can add fet cascodes around the jfet CCSs, if you need more voltage capability.
Old 13th October 2012, 05:49 PM   #87
wahab is offline wahab  Algeria
Originally Posted by gaborbela View Post
Hello
Zen Mod
Please let me know.
Thank you
Greetings Gabor
The collector and the emitter should be inverted in your schematic.
Also , using bipolar would allow to reduce the zener to a few volts ,
extending the maximum voltage swing , although it s doable
with mosfet current source , just take a 5.1V zener and set R3 to 470R ,
while R2 is to be changed to 1.5K.
The original value of 1.8K along with a 15V zener was indeed
not the good set in respect of the original schematic wich
used a 16K resistor to set the input stage current at about 4mA ,
while the combination Z15V/1K8 would have provided 8mA or so.
Anyway , once you have made the choices of components
i will do a few sims to check grossly how this work.
Old 13th October 2012, 06:41 PM   #88
Hello wahab
Thank you very much, sim would be great it would save a lot of energy and time. Eaching PC board, soldering etc.
I made those mode you ask for change those parts values, I hope now those BJT-s are OK.
(Usually collector connected to the supp voltage that is why I made that way.)
In case still no good I will re do it again.
Since I don't know those BJT-s drawn correct or not.
Any way I will stick with these Toshiba 2SC3423 transistor we already chose for cascode to.
Thanks one more time!
Greetings Gabor
Old 13th October 2012, 06:49 PM   #89
donpetru's Avatar
In the last diagram posted above, increase the value of R3 to 1K or decrease the value of Rt.
Old 13th October 2012, 08:26 PM   #90
Hello wahab
Greetings Gabor
Here a schematic that will summarize the lasts changes.
Some resistors are brought to the closer E12 values ,
such as 1.6K being changed to 1.5K in the input differential
current source collector.
Also , the gain is increased to 33 as the original value , 22 , is too low
for the expected output voltage , it is even likely that it must be
increased even more but it ca be changed later by swapping
the usual resistor.
A diode + led are connected in parralel with the biaising trimmer ,
as this will limit the current if ever the trimmer goes broken
or if it is too much rudly handled , in both case the led will
be bright only with faulty conditions.
The two compensation capacitors are increased to 47pF
to prevent oscillations , they can be later experimentaly reduced
to a lower value.
Midgard, a low distortion Lateral FET output Headphone Amplifier Neutrality Headphone Systems 8 14th December 2012 07:31 PM
Thor, an all discrete Lateral FET Headphone Amplifier. Neutrality Headphone Systems 163 5th November 2012 02:53 PM
Mjølner, another all discrete Lateral FET Headphone Amplifier Neutrality Headphone Systems 13 13th October 2012 07:42 PM
hitachi lateral power mosfet in pspice JBnl Solid State 2 12th March 2005 04:49 PM
Lateral MOSFET replacements for 2SK1058 (Hitachi) jgwinner Solid State 25 11th June 2003 11:59 PM
Copyright ©1999-2013 diyAudio
