#51 | |
variation in their drain voltage to correctly make the VAS swinging the full rail voltage, hence the latter provid most of the gain. That s about 1% of the 9.6V VGS provided by a 10V zener in the cascode, wich will be hardly a limiting factor. |
#52 |
If you choose 2SK170GR then every J-FET will be polarized at a current of approximately 3 mA, which means a total current of 6mA for CCS on the input. In this case, change the values of R1 and R2 as follows:
R2 = (0.8 * Uzener_D2 - 0.7) / I_vas, where I_vas = 0.006 A. R2 = (0.8 * 15 - 0.7) / 0.006 = 1833 Ohm - you can choose 1k8 And the value of R1 will be: R1 = Vcss / I_css = 10 / 0.006 = 1666 Ohm - choose a default value of 1K5 or 1k6. Again, attention to the current input circuit; 6mA current is quite large - using a popular expression - can gather a lot of noise but worth trying. Let us know here on the experimental stage of this amplifier, some opinions, after the first version of the prototype. Then will apply improvements that will be necessary. Good luck. Later edit: @wahab, I understand your point of view. It's a good point.
PCB Design Services - for prototypes OR serial products, Today Tehnium and Forums Last edited by donpetru; 8th October 2012 at 04:50 PM. |
#53 | |
donpetru Thank you once more !GR IDSS rating 2.2 to 6mA, I will pick the lowest matched 2PC I have. I upgraded the circuit after the advised value I still need some value for start for D2, for R3 if I remember well you wrote 4K7 is wrong value Do I keep HZ15V or go back to 10V? @wahab, I understand your point of view. It's a good point I added a input capacitor, I will start with 4.7uF after the test (I'll hear the amp (sound)tone) I will decide about that. I will work on the layout so I can start testing what we have now. I'll buy the missing parts (resistors and diodes) tomorrow. Thank you for the help to all of you! ![]() Greetings Gabor |
#54 | ||||
R3 = 2k4, as I said here:
http://www.diyaudio.com/forums/solid...le-naim-5.html In that post I wrote wrong only this part: Quote:
Now, replace the part above from quote with this: Quote:
PCB Design Services - for prototypes OR serial products, Today Tehnium and Forums |
#55 |
Thank you donpetru!!!
Upgraded circuit Greetings
#56 |
Hello
Just finished the layout for the amplifier. So soon I can start test her. I draw with my computer paint program so I use color code for the parts. Red- mosfet, JFet, transistor Green- resistors Blue- capacitors Grey- trimmers Yellow- jumper Purple- diodes So here is it if someone interested, the layout not tested yet but I drew more than a dozen of layout like these, 99% work at first. ![]() Greetings Gabor |
#57 |
Hello
Here is the all black layout. The right size 139 X 73 mm. Greetings |
#58 |
Some transistors (eg. VAS circuit) will need a heat sink. Do not forget that.
#59 |
Before building this amp , a few points that matters if black smoke
is not the goal... The biaising trimmer should be about 500R , as already pointed , if you use Renesas/Hitachi laterals wich have low Vth. It seems that there is two critical flaws in the schematic. The first is that the VAS current source as well as the differential current source voltage reference , D2 , is fed by one leg of the differential VAS , wich is surely a mistake in the schematic. Second , the differential fet current source has a diode , D1 , in serial with its gate that is placed the wrong side. Last edited by wahab; 12th October 2012 at 12:28 AM. |
#60 |
T7, T8,T9 could be bipolar too .
Maybe just keep the input transistors and power output stage as fet's. Would it make an 'audible' difference ? It certainly would be easier to build !
AM |
| Midgard, a low distortion Lateral FET output Headphone Amplifier | Neutrality | Headphone Systems | 8 | 14th December 2012 07:31 PM |
| Thor, an all discrete Lateral FET Headphone Amplifier. | Neutrality | Headphone Systems | 163 | 5th November 2012 02:53 PM |
| Mjølner, another all discrete Lateral FET Headphone Amplifier | Neutrality | Headphone Systems | 13 | 13th October 2012 07:42 PM |
| hitachi lateral power mosfet in pspice | JBnl | Solid State | 2 | 12th March 2005 04:49 PM |
| Lateral MOSFET replacements for 2SK1058 (Hitachi) | jgwinner | Solid State | 25 | 11th June 2003 11:59 PM |
