All Hitachi Lateral Fet amplifier for DIY described by Paul Kemble - Page 36 - diyAudio
Old 18th December 2012, 04:55 AM   #351
wahab is offline wahab  Algeria
Large signal mode sim using a 5Khz sine surimposed with a 100KHZ square
signal at 4/1 ratio, quite a stressfull test to check unstabilities that can occur
at some specifics output levels.
The imperfection in the curve are due to the conversion from EMF to GIF ,
otherwise everything is straight...
Old 18th December 2012, 08:52 AM   #352
Hi Wahab ,
I did Goldmund clone 9.2 which frankly are very pleased.
But I am very curious to try your scheme
Please tell me if I can use without modification 2n5565 and 2sk176/2sj56.
Thank you!
Old 18th December 2012, 09:19 AM   #353
Hi Vitalica ,
For the input stage it s better to stick with the 2SK170 , the 2N is not as good,
it suit better the GM since its limited transconductance is part of the design stability ,
but for this amp that is stabilized for a higher feedback it would just degrade the perfs.
Other models are possible , though , i ll check and post my findings soon.
In contrast , the 2SJ56/K176 suit perfectly this amp , of course , it is likely
that they are even better than the 2SJ162/K1058 but as you can see , Gabors
PCB suit the latter so you ll have to either mod it or mod Alex s PCB wich is more
complex to implement if home made.
Btw , your amp is nicely built...
Old 18th December 2012, 11:08 AM   #354
Thank you very much ,Wahab
I'll talk to Alex mm, can help me change a little PCB.
Old 18th December 2012, 05:38 PM   #355
An exemple of the test above with a comparison between this amp
and another one that i took randomly from the forum.
First picture show the two curves , with Gabor amp s having
slightly higher power output so we can differentiate them clearly when
zooming , first a part of the positive side and then the negative
side of the signal.
The test clearly show little glitches with the amp X that are due
to a compensation that is not accurate although i improved it slightly ,
otherwise the curve would really look ugly.
Thoses glitches would be likely not observable with a single pulse
that swing the same total amplitude.
Old 18th December 2012, 08:12 PM   #356
EDDELARUE's Avatar
Send a message via MSN to EDDELARUE Send a message via Skype™ to EDDELARUE
I think that open loop gain is changing with output swing voltage ( decreasing ). It may to originate that glitches. You can to see it happens only near the peak output.
eD
Old 19th December 2012, 12:03 AM   #357
Quite possible , i still didnt investigate the thing since i discovered
this behaviour only when performing this sim recently.
That said , dont pay too much attention to the full amplitude graph
as the image converter EMF/GIF distort the picture hugely.
Old 19th December 2012, 06:48 PM   #358
alex mm is offline alex mm  Romania
alex mm's Avatar
.........layout for Vitalica
Old 20th December 2012, 03:51 PM   #359
I am very impressed Thanks Alex, I love it!
Old 12th January 2013, 01:58 PM   #360
ashok's Avatar
So has anyone built this amp and listened to it ?
AM
Lateral MOSFET replacements for 2SK1058 (Hitachi) jgwinner Solid State 26 12th June 2014 07:33 PM
Midgard, a low distortion Lateral FET output Headphone Amplifier Neutrality Headphone Systems 8 14th December 2012 07:31 PM
Thor, an all discrete Lateral FET Headphone Amplifier. Neutrality Headphone Systems 163 5th November 2012 02:53 PM
Mjølner, another all discrete Lateral FET Headphone Amplifier Neutrality Headphone Systems 13 13th October 2012 07:42 PM
hitachi lateral power mosfet in pspice JBnl Solid State 2 12th March 2005 04:49 PM
Copyright ©1999-2017 diyAudio
