All Hitachi Lateral Fet amplifier for DIY described by Paul Kemble - Page 21 - diyAudio
Old 21st November 2012, 10:04 PM   #201
Hello
Sorry guys I was out for a couple weeks. Now I feel better so back to the project.
I'm looking to get the right transfer paper (from Staples) because I run out of them.
After I will do the PC boards and I will start test the amp. I think I will order PRP resistors that is a great match to the Hitachi laterals..
Thanks for your patient.
Greetings Gabor
Old 22nd November 2012, 11:18 PM   #202
alex mm is offline alex mm  Romania
alex mm's Avatar
..... another kind of PCB acording to schematic from post #194
Regards Alex.
Old 22nd November 2012, 11:29 PM   #203
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
Nice job, Mr. Alex.
Please.... SCHEMATIC WAHAB or SCHEMATIC GABOR?
Thanks!
Max.
Old 22nd November 2012, 11:50 PM   #204
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
nice looking board
but not sure I would like to mount the output transistors like that on a heatsink
and speaker out placed so close to the power supply lines/connectors, is that good ?
Old 23rd November 2012, 12:50 AM   #205
wahab is offline wahab  Algeria
Originally Posted by gaborbela View Post
Hello
Greetings Gabor
Hi Gabor ,
Hope all is well for you.
As for special resistors , just take regular non inductive ones ,
expensive parts are useless by the way , most of the perfs
are active components dependents.
Regards Alex.
Nice board , Alex.
Old 23rd November 2012, 12:54 AM   #206
Originally Posted by smartx21 View Post
Nice job, Mr. Alex.
Thanks!
It is on post 194 but neverless here it is again.
Old 23rd November 2012, 02:49 AM   #207
ashok's Avatar
Is C6 across R16 for stability ? Should introduce a zero in the OL gain?
And R33 (10K) does go to the output node and not to the + supply rail ?
AM
Old 23rd November 2012, 03:21 AM   #208
Yes , it slightly extend the unity gain frequency from 15.5Mhz to 18Mhz
but the most valuable change is efficient reduction of the phase lag
at thoses frequencies.
You can see that R33 is an AC coupling only , from power output to the inverting input of the VAS to create a local feedback loop that act only at audio frequencies and wich is quite efficient in output stage THD reduction as extensively explained by Edmond Stuart in his insightfull threads about TMC , wich is exactly the role of the compensation capacitors arrangement C3/C2 and R33.
edit : If R33 is connected either to ground or + supply rail the compensation scheme
would be switched from TMC to TPC.
Old 23rd November 2012, 09:52 AM   #209
Sorry for not being clear.
I meant: Alex wrote on the PCB the words SCHEMATIC WAHAB. I am asking if this schematic comes from you or from Gabor.
Thank you!
Max.
Old 23rd November 2012, 10:06 AM   #210
ashok's Avatar
.............. If R33 is connected either to ground or + supply rail the compensation scheme would be switched from TMC to TPC.....
Yes that was what I was getting to.
AM
Lateral MOSFET replacements for 2SK1058 (Hitachi) jgwinner Solid State 26 12th June 2014 08:33 PM
Midgard, a low distortion Lateral FET output Headphone Amplifier Neutrality Headphone Systems 8 14th December 2012 08:31 PM
Thor, an all discrete Lateral FET Headphone Amplifier. Neutrality Headphone Systems 163 5th November 2012 03:53 PM
Mjølner, another all discrete Lateral FET Headphone Amplifier Neutrality Headphone Systems 13 13th October 2012 08:42 PM
hitachi lateral power mosfet in pspice JBnl Solid State 2 12th March 2005 05:49 PM
Copyright ©1999-2017 diyAudio
