#191 |
Hello wahab
I made the mode on the layout but I'm not 100% sure if is correct. Please forgive me I'm very tired, can you take a look please .I use BC550/560 transistors, not face to face because that here isn't important. I have another question Can I use only 2PC capacitor in my amp power supply as efficient like 4PC CRC or CLC? I have 4PC Kendeil capacitors 50V 50 000uF and I want to use them in a pair mono block (in my Darlington) Now if two cap does not do as good job like CRC or CLC that case I have to purchase 4PC more. They are very expensive.. To use other type caps and degrade the quality of the Kendell that would be waste of money to. I did built PS with two caps, it was not bad but I never compared with CRC or CLC type set up. Actually the 2x50 000uF already over kill here.. I did purchased to use in my bridged ProFet clone, but that amp does not deserve to use those caps there because the Darlington sound that much better. I see several good brand amp use only 2 large can cap in PS. Greetings Gabor Last edited by gaborbela; 10th November 2012 at 12:23 AM. |
#192 |
dear sir,
plz also show me assembelled kit. thanking you |
#193 |
#194 |
Hello
Here is the layout I did include the last requested mode! Yesterday I was very tired (not about the amplifier) the reason I do ask if the last mode is correct. I'm sure it is correct. Again if someone want to print out the layout please open it with the paint program, set up the printer (PAGE SETUP) 90% and that is the correct (right) size. Any question you have about the layout I'll gladly answer it. Thank again for the upgrade on the circuit! Greetings Gabor |
#195 |
Gabor have asked to have a few posts moved to other thread
My firs DIY amplifier 20 years a go ![]() moderation |
#196 |
Thank you very much!
Greetings G |
#197 |
Back to topic , some sims of the amp s expected caracteristics ,
with some comparisons with the much appreciated Goldmund Mimesis.
#198 |
Hello
Very-very nice Thank you wahab! I hope there will be more interest to build these amp. Greetings Gabor |
#199 |
Hi Gabor,
Hope it will live up to expectations , that s somewhat of an extreme amp , the cascoded input stage + current mirrored cascoded differential VAS structure has not been often used despite promising perfs. Also , looking at a picture of your laterals , we can see that you have marked them 0.88 or 0.89 , is it the gate/source voltage for 100mA current.?. |
#200 |
Hello
I just simple match those after N Pass instruction. All do his matching is for vertical. I match those under 16VDC and 30sec. All started to warm up a bit until the end of 30sec (no heatsink used because take to long time the mouthing) Greetings Gabor |
| Midgard, a low distortion Lateral FET output Headphone Amplifier | Neutrality | Headphone Systems | 8 | 14th December 2012 07:31 PM |
| Thor, an all discrete Lateral FET Headphone Amplifier. | Neutrality | Headphone Systems | 163 | 5th November 2012 02:53 PM |
| Mjølner, another all discrete Lateral FET Headphone Amplifier | Neutrality | Headphone Systems | 13 | 13th October 2012 07:42 PM |
| hitachi lateral power mosfet in pspice | JBnl | Solid State | 2 | 12th March 2005 04:49 PM |
| Lateral MOSFET replacements for 2SK1058 (Hitachi) | jgwinner | Solid State | 25 | 11th June 2003 11:59 PM |
