#121 |
Had a look at the files from the link you posted and could not find any simulations of IMD for the F5, only THD.
And the distortion spectra from the F5 simulation dont look like those NP measured with an AP.
Regards, Georg |
#122 | |
The Nelson Pass THD measurements you re talking about are made at 1W RMS output power....
#123 |
At least they are measurements. Estimating IMD from a THD simulation that does not match
reality makes no sense to me.
Regards, Georg |
#124 | |
at about 6W RMS while nelson pass did measurements at 1W (for an amp that basically dissipate 100W/channel.. )....Anyway i also simulated IMD ratios for this amp and they are quite high. Of course , i dont simulate at 1W level , as as such low levels almost any amp will appear as good enough and Nelson Pass knows it... Last edited by wahab; 19th October 2012 at 02:28 PM. |
#125 |
wahab, please refrain from telling me what I understand and what not, OK ?
I have yet to see if real world measurements match your simulations.
Regards, Georg |
#126 | |
Thank you, I did corrected! I have some question about the following capacitors. C9 & C10 is 1 000uF? C7 & C8 is 10 000uF? I need to know because the size of the capacitor on the layout. Do the amplifier can be fully driven from a CD player or will need a preamp? Please let me know Thank you very much! ![]() Greetings Gabor |
#127 | |
at 1Khz /20W (not good enough for CD standard) Nelson Pass specifies it at 1% THD/25W.... http://sportsbil.com/other/NELSON%20...WATT%20AMP.pdf Besides , this amp has low gain as he used as much as possible of it to increase NFB resulting in a meager 15dB voltage gain. Reducing the gain of the amp discussed in this thread ( wich is about 30dB) to the same value , would reduce its distorsions by 15dB , i let you imagine what would the difference become compared with the F5 in the graph above... |
#128 | |||
of 220uF on the amp PCB for wires decoupling. Quote:
if necessary the gain can be increased without substancialy altering the global perfs just by swapping the relevant resistance , R13 in the schematic below. On another note , hope that your artwork is still in the doing as it would be valuable to slightly mod the differential and VAS current sources voltage references in a way that at powering on the input stage and upper side of the VAS become functionnal before the VAS current source start to conduct. This way , the negative feedback will be available micro seconds or so after the amp is powered on and any eventual pop will be suppressed or at least reduced to a meaningless amplitude. Also , it appeared that one of the 33pF compensation capacitor of the VAS was simply useless , it can be suppressed. For the remaining 33pF compensation capacitor , it must be connected with a distance as short as possible from the base of Q6 to Q8 collector. Also , the track joining Q6 collector to Q8 emitter must be short as well. On the components side , the transistors used are among the most adequate for the intended purpose but if they are either too expensive or too difficult to find there are other models that can be used , just let me know about it and i ll provide a list of valuable replacements. I put the updated schematic below , sorry for the late mods, but happily it is the last ones. |
#129 | |
1. increment LTP tail current as jfet vorks bettter close to the Idss. 2. use floating cascode for the LTP, look at attachment. 3. Use Hawksford enhaced cascode for VAS. 4. You do not need to have the same impedance at the jfet LTP input and FB, you can use much smaller resistor for the FB and could do without capacitor. dado |
#130 |
This is interesting, first many claim that simulations results make THD look better than possible real world results.
GK7 youre claiming it makes a good amp look bad. ![]() Btw Wahab is correct, High THD means high IMD. F5 doesnt have low distortion figures but tube amps have even higher and are loved by many although it doesnt mean that they reproduce sound accuratly. Many prefer music with sound effects which is what these high distortion amps do, including F5. F5 is probably the worst amp I ever played through my BW 804s, even a secondhand 30 euro cheapie rotel sounds better especially with regards to bass. It is not everyones cup of coffee nor does it match many types of speakers. |
| Midgard, a low distortion Lateral FET output Headphone Amplifier | Neutrality | Headphone Systems | 8 | 14th December 2012 07:31 PM |
| Thor, an all discrete Lateral FET Headphone Amplifier. | Neutrality | Headphone Systems | 163 | 5th November 2012 02:53 PM |
| Mjølner, another all discrete Lateral FET Headphone Amplifier | Neutrality | Headphone Systems | 13 | 13th October 2012 07:42 PM |
| hitachi lateral power mosfet in pspice | JBnl | Solid State | 2 | 12th March 2005 04:49 PM |
| Lateral MOSFET replacements for 2SK1058 (Hitachi) | jgwinner | Solid State | 25 | 11th June 2003 11:59 PM |
