Old 1st October 2012, 11:50 PM   #1
Default Anyone use this fan to mod the EP4000
Aavid Thermalloy 80 mm Fan - 24 V - Quiet and High Flow
  • Brand new fan made by Aavid
  • Model No. 148A331
  • 80mm x 80mm x 25mm
  • 24 Vdc, 70 mA
  • Ball bearings
  • 2000 RPM
  • 28.4 CFM
  • 22 dB
  • Outgoing leads are 11" long
I bought two of these amps as a cheap 2nd party system in a game room but the fans are getting to me.
Old 1st October 2012, 11:52 PM   #2
Or is a simple resistor a better way to go? The stock fan is 56cfm so just cutting down its speed will acheive the same thing while cutting down on noise on quiet days.
Given the above specs, what resistor value would you recommend? The big advantge here is you can add a switch to adjust the speed.
Old 2nd October 2012, 11:42 AM   #3
thanks
Hafler 9270 Toroidal Xfo Mod - A Different Hafler Mod Taterworks Solid State 2 14th December 2012 05:42 PM
EP4000 fan mod part number SpinMonster Solid State 3 25th June 2012 01:55 PM
FS: Behringer EP2500 Amp w/ Fan Mod Nichol1997 Swap Meet 0 6th January 2011 03:03 AM
Mitsubishi DD-8040: to mod or not to mod? FastEddy Digital Source 0 4th November 2006 01:20 AM
Marantz CD75mkII to mod or not to mod that is the question. El_Hefty Digital Source 6 31st August 2006 01:29 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
