#81 |
Hei Mooly if you are so ""willing "" with simulator i think i will send you a few circuits to simulate for me ( second opinion is always something to listen to )
I have a few ideas id like to share but i am not that good in simulators I have an example also that i would like to talk about Can i Pm you ? Sorry for the off topic Kind regards sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#82 |
PM sent
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#83 |
So guess what?
The PNP 2SA1142 measures as a NPN!!! Via Diode test and hfe test... D*MN! Since the original NEC 2SA1142 is a green body unit.....and this was a black body unit....I should have noted... It is a rebadged NPN from China.... D*MN!!!! It just didn't seem like it was possible being a basic cheap transistor.. It teaches me a lesson to check each one before I put it in the circuit. I just didn't see this coming! I'm mad at myself! Lesson learned... Just Move on.... I will let you know when it is all back together & working...
Dan |
#84 | |
Minimum voltage across Q617 is 3.25V & maximum is 3.68V when adjusting the pot. 22K resistor attached to Q617 E 3.2V drop across Q617 C & E 1.2V drop across Q617 B & E 2.0V drop across Q617 B & C Relative to ground: Q617 E is 0.2V Q617 B is 1.4V Q617 E is 3.4V Question: If the feedback resistor is not connected to Q617, I do get voltages near +Rail voltage (~3-4volts less than +Rail voltage) for all 3 measurements with the .6V across the junctions (BE & CE etc.). Is this normal or does it point to other remaining problem.... other than the so called Counterfeit PNP 2SA1142 which is actually a NPN. Let me know what you guys think Thanks
Dan |
#85 |
Ohhh a counterfeit
That explains a lot.See post #128 here (and the whole thread )My Transistors, original or copy? As to testing the amp and the feedback resistor connection. The feedback resistor is essential to establish the DC conditions in the amp. What you have with all the front end circuitry is really a discrete "opamp". There are two inputs, the bases of Q601 and 607 and the bases of Q603 and 609. These are the "non inverting" and "inverting" equivalents respectively to an opamp. From only the feedback resistor and R613 we can calculate the gain of the amp. Operational amplifier - Wikipedia, the free encyclopedia Your voltages seem "OK" in a broad sense. tbh I would have expected Q617 E (the point where the feedback resistor connects) to be a little nearer to zero. Although 0.2 volts is low, if that ends up as a DC offset at the output of the amp then it's not really low enough... I think at this point we say its OK. The amp is missing the "slow" output stage and its conceivable that there could, under the present test conditions, be some small HF instability upsetting the DC readings. Lets assume its good to go If the feedback resistor is missing then the voltages on Q617 will swing toward the rails as you have found. So no problem there. Its the voltages across Q617 that determine the bias current in the output stage rather than absolute values above and below ground. The range of adjustment seems a little small as I suspected, but thats down to the resistor values and could equally be called good design as it provides fine adjustment in the right "zone". Nothing worse than presets that are all or nothing and where a degree or two of rotation cause the current to jump wildly. So set the preset to the end that gives the lowest voltage across C and E of Q617 What I would suggest before initially powering up after replacing the parts is to check carefully that all parts are correctly fitted and that all the caps that you lifted are replaced. Also don't forget to refit the feedback resistor back to its original location. I would power up the fully rebuilt amp (with the bulb tester of course) initially with Q617 still shorted C and E. The amp should work perfectly like that. The only problem with no bias is that you might hear slight crossover distortion at very low volume.
#86 |
Hmmm, wish I had posted that it had occurred to me a couple of times that it looked like NPN-behaviour in the replacement for Q613. Even the thought it being a counterfeit had crossed my mind but I dismissed it.
Well, at least you've come to this conclusion methodically. And the good news is that it indeed looks like you're good to go! |
#87 |
Thanks guys - Mooly & Jitter for sticking with me and my next steps are as follows:
So I: 1) will put back Q619 & Q621 (C2910/A1208) in the circuit 2) add the feedback resistor back to the emitter resistors of the outputs 3) and leave the Q617 C & E shorted 4) leave the bulb in series with AC line 5) power up & make measurements to determine correct voltages/dim light If everything seems to be fine such as dim light & correct voltages then I will: 1) power down & remove test bulb out of AC line 2) remove the jumper across Q617 C & E 3) add #1 meter across testpoints T1/T3 4) add #2 meter across outputs to measure DC @ outputs 5) power up 6) adjust bias to 7mV Any flaw to this plan other than maybe adding leaving in the bulb in the circuit while I begin to adjust bias as I have other channel disconnected and the load is less than the 60W bulb's influence on the current delivery to amp? Let me know Thanks in advance,
Dan |
#88 |
Looks good.
Personally, when finished, I would recheck and, if necessary, readjust the bias with the amp in normal working conditions; i.e. without bulb and with both channels connected to power supply. |
#89 |
Thanks Jitter.... I will move forward with this plan and I will leave the bulb in for the 1st adjustments.... just in case...
Dan |
#90 |
That all sounds good. I would probably leave the bulb in place after removing the short on Q617. You just never know... and its a good safeguard for an initial power up with the bias generator active. If the bulb is still dim when the short is removed and then begins to glow as the preset is turned you know its looking good. At the first sign of the bulb glowing as the preset is turned, you should then turn it back down, switch off and remove the short and set it up for real.
Once the bulb begins to light then the filament starts to increase in resistance rapidly and that causes the rails to collapse. So its just used for initial testing only. Never attempt to set the bias with the bulb present because the supplies will be a lot lower than normal. Also do not have any speakers connected during any tests or adjustments. I'm not sure what transistors you actually have fitted at the moment but if they are suitable then there is nothing stopping you testing it out now. As long as the devices fitted are adequately rated then the amp should all work as intended. Are you happy with Q619/621 that you have and all the rest of the output stage or would you like some more simple tests to see all that part of the circuit is OK first ?
| Rotel RB-1010 power amp varistor! | Rosscopecotrain | Solid State | 25 | 14th January 2013 07:32 PM |
| Rotel RB-871 Mark II Channel Imbalance | dtm1962 | Solid State | 20 | 25th July 2011 03:01 AM |
| Rotel RB 990BX Cicuit Protection | The Kook Abides | Solid State | 1 | 1st February 2011 12:49 AM |
| FS: Rotel RB-976 6X60 power amp | Bill Fitzpatrick | Swap Meet | 4 | 14th April 2005 12:27 AM |
| Rotel RB-990BX Supply Voltage | tab30 | Solid State | 4 | 22nd August 2003 03:09 PM |
