Help Needed: Excessive DC Offset/Imbalance - Rotel RB-990BX Power Amp - Page 6 - diyAudio
Old 7th October 2012, 08:34 PM   #51
Mooly's Avatar
Typo above... I did a quick edit but you might have the wrong info
Should read " If it doesn't then Q613 is faulty (leaky).
Old 8th October 2012, 04:52 PM   #52
jitter is offline jitter  Netherlands
jitter's Avatar
I agree with Mooly that Q613 might be leaky.
Looking at the voltage drop across R623 (in the first pdf of post #41 ), it seems that a lot of current is flowing through it, i.e. 36 mA, despite Q613 supposedly being off (B is more positive than E).
Q615 seems to be turned on and there's -41 mA flowing through it at quite a large voltage differential between C and E, which might explain why it gets hot.
Old 8th October 2012, 05:08 PM   #53
east electronics's Avatar
Originally Posted by sakis View Post
Just last night i had to fix a HK 870 with 7 volts of offset in the one out ...Nightmare to remove piggy board of drive to measure and/or exchange transistors with no success but while looking equipped with a second pair of eyes i noticed a good crack on the pcb solder it fixed in seconds
you may inspect that also
As Ian said the best approach is to measure always looking at the working Chanel for reference ,
Often there is a case where a transistor measures quite properly with a DVM or even a hfe tester but fails under 50-60 volts you must observe that also
Finally if the offset is positive you may start swapping parts of the +rail from the working channel but always with caution .
starting swap point should be transistors Q613 -619 - 635 ( this will be of course after verifying proper voltage conditions )
NOTE :
( at the specific amp consumption is fairly low also bias is fairly low .... 60 W bulb may drop the mains a few volts but not half of it .Behavior like that means that one of your transistors is conductive fully open when powered and that brings us to the point where a semi looks ok outside the amp but not when powered with 50-70 volts )
Kind regards
sakis
well ...
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 8th October 2012, 06:11 PM   #54
Mooly's Avatar
well ...
well indeed
I always like using my old AVO to test transistors. The 15 volt battery on high ohms range soon shows any leakage. DVM's just don't cut like the gear Mind you, you have to do the mental juggling of reversed polarity on an analogue meter, the red lead is negative on ohms... just to confuse you.
Old 9th October 2012, 02:56 AM   #55
dtm1962 is offline dtm1962  Canada
Default Update
Thanks for the input Mooly, Jitter, Tauro0221 & Sakis....
I will test the Q613 out tomorrow (as Mooly has suggested) as I had a busy last couple of days doing family things!
I will update you on the outcome....
Thanks again guys!
Dan
Old 10th October 2012, 12:58 AM   #56
Default Measurements Update
This is the tests as suggested by Mooly.....
A quick and dirty test... remove Q613 and see if the voltage on Q617 (still shorted) falls to near the minus supply rail.
If it does replace Q613 but leave the BASE unsoldered and floating. Again see if the Q617 volts falls away. If it doesn't then Q613 is faulty (leaky).
Here is the results of the above tests:
Q617 C & E shorted.... and Q613 removed from board
E = -0.4V
C = -0.4V
B = -0.4V
Q617 C & E NOT shorted.... and Q613 removed from board
E = -65.4V
C = -65.4V
B = -64.7V
Q617 C & E shorted.... and Q613 ON BOARD but BASE Disconnected
E = +49.6V
C = +49.6V
B = +49.6V
Q617 C & E NOT shorted.... and Q613 ON BOARD but BASE Disconnected
E = +46.3V
C = +49.6V
B = +47.0V
Does this mean that Q613 is SHORTED & Q615 IS OPEN?
Let me know what you think....
Thanks in advance,
Dan
Old 10th October 2012, 05:37 AM   #57
jitter's Avatar
E = -0.4V
C = -0.4V
B = -0.4V
It didn't, so I'm not going to take any conclusions from the two below.
E = +49.6V
C = +49.6V
B = +49.6V
I'd like to know more voltages such as:
- the voltages on the bases of Q613 and Q615.
Please also report voltages in above situations of:
- positive and negative supply rail;
- on E of Q613;
- on E of Q615.
With the above three, you can calculate the voltage drops across the resistors and then with I = U/R the current through them. The currents through these resistors inherently also flow through the emitters of the transistors under investigation.
Please write them down in the schematics like in post #41, it helps visualizing things.
Old 10th October 2012, 06:38 AM   #58
Mooly's Avatar
From the latest readings Q613 appears faulty.
With the base disconnected it should appear to the circuit as if it has been removed and it doesn't. In both cases the voltage on Q617 comes back to around +50 volts. So that is one problem. Based on those reading Q613 is faulty.
I can't reconcile the different results of Q617 being shorted and not shorted although that does not alter the above.
For interest have you measured Q613 out of circuit and on a high ohms range. Thats the range that would measure resistors in the Meg ohm region and the range that shows a reading with you just gripping the leads. Assuming a normal DVM then with the black lead on C and the red lead on E there should be no reading. It should read as if the leads were just open.
Old 10th October 2012, 06:53 AM   #59
E = -0.4V
C = -0.4V
B = -0.4V
Q619 and Q621 removed from board
The result if this test I can not follow it. If you shorted Q617 collector to emitter then the E and the C should read negative but it read -0.4V. Where the positive voltage it is coming from to read -0.4V. If you removed the jumper then everything read negative.
E = -65.4V
C = -65.4V
B = -64.7V
The only way to feed a positive voltage is from C613 leaking.
dtm1962 can you remove C613 and do the test again.
Old 10th October 2012, 07:00 AM   #60
Mooly's Avatar
It is a strange result for sure. Certainly its worth checking the cap for leakage.
Rotel RB-1010 power amp varistor! Rosscopecotrain Solid State 25 14th January 2013 07:32 PM
Rotel RB-871 Mark II Channel Imbalance dtm1962 Solid State 20 25th July 2011 03:01 AM
Rotel RB 990BX Cicuit Protection The Kook Abides Solid State 1 1st February 2011 12:49 AM
FS: Rotel RB-976 6X60 power amp Bill Fitzpatrick Swap Meet 4 14th April 2005 12:27 AM
Rotel RB-990BX Supply Voltage tab30 Solid State 4 22nd August 2003 03:09 PM
Copyright 1999-2017 diyAudio
