Help Needed: Excessive DC Offset/Imbalance - Rotel RB-990BX Power Amp - Page 5 - diyAudio
Old 7th October 2012, 04:21 PM   #41
dtm1962 is offline dtm1962  Canada
Default Schematic Measurements With Q617 CE Shorted & Without
Here are measurements that are made today as well.
1st Attachment is with Q617 C & E Shorted and
2nd Attachment is with Q617 C & E not shorted
Note: Q619 & Q621 are removed to isolate the outputs from the measurements....
Note the +/- Rail Voltage does dip by ~3VDC when Q617 C & E is shorted.
If you want higher resolution pdf's of the measurements...
please email me dmullins at cogeco dot ca
Let me know what you think
Thanks in advance,
Dan
Old 7th October 2012, 07:17 PM   #42
Default Update Revision 1
Thanks in advance,
A few revisions was worth redoing the attachment.
For some reason +/- Rail voltage would vary enough (+/-3Volts) to make some measurements invalid, hence my reissuing the attachment for "the non-shorted Q617 C & E version". The Shorted version is accurate as is.
The 3 updated voltages are "back circled" for reference.
Let me know your thoughts.
Again Higher resolution copy of marked-up schematics are available if you email me at: dmullins at cogeco dot ca
Thanks in advance,
File Type: pdf RB 990 Q617 C E NOT Shorted REV 1 Measurements.pdf (132.9 KB, 37 views)
Dan
Old 7th October 2012, 07:29 PM   #43
Mooly's Avatar
Its easily done and no problem
I've just amended the circuit to show two your new readings so I'll have look and see if I can make any sense out of them.
If you want to do a new set of readings that's fine and is a good double check.
Installing and using LTspice IV. From beginner to advanced.
Old 7th October 2012, 07:31 PM   #44
Mooly's Avatar
Lol, I didn't turn the page... I''ll study your results
Old 7th October 2012, 07:55 PM   #45
Mooly's Avatar
Heres what I'm thinking so far...
Two of your results show Q613 with 62.6v on the emitter and 60v on the base. Something amiss there. Can you recheck that measurement under the same conditions and also check by measuring across the B-E junction as well. Thats very important. That B-E drop must not exceed around 0.8volts with the emitter more positive than the base. If it does we might have a problem with that device.
The other result shows Q613 with the base positive with respect to the emitter (so Q613 should be off) and yet there is still nearly 60 volts on the collector. So again that reading also points at Q613
Now there may be other problems too but this seems like one identifiable issue that we must correct first.
I would still leave Q617 shorted as it takes all the circuitry associated with it out of the equation.
Old 7th October 2012, 08:43 PM   #46
Default Measurements Update
Hi Mooly:
Here are the results:
A) Q617 C & E shorted...
Q613 BE voltage drop = -0.6V drop with Red lead on E & black lead on B
=+0.6V drop with Red lead on B & black lead on E
Q613 voltages ref to ground = E = +56.5V; +57.3V; +56.7V
B) Q617 C & E NOT shorted...
Q613 BE voltage drop = -1.5V drop with Red lead on E & black lead on B
= +1.5V drop with Red lead on B & black lead on E
Q613 voltages ref to ground = E = +60.2V; +58.5V; +58.1V
Note: When Q617 C & E is shorted that the rail voltages goes down....
I hope this helps.
Thanks in advance,
Dan
Old 7th October 2012, 08:50 PM   #47
Molly the voltage at the R627 one side read -58.8 volts and the other side +59 volts. The plus side should read +1.2 volts. No? Can he check the resistor R627 for open.
Old 7th October 2012, 09:11 PM   #48
[QUOTE=dtm1962;3193047]Hi Mooly:
QUOTE]
So it should read as I forgot to identify the last 2 voltages for each...
Q613 voltages ref to ground = E = +56.5V; BASE +57.3V; COLLECTOR +56.7V
Q613 voltages ref to ground = E = +60.2V; BASE +58.5V; COLLECTOR +58.1V
Dan
Old 7th October 2012, 09:15 PM   #49
R627 measures correct as it is 1/2W MF Dale versus 1/4W generic MF type as I have changed it out a couple of times. The ones I remove always mesures within 1% as well...
Dan
Old 7th October 2012, 09:30 PM   #50
Mooly's Avatar
Hi Dan,
I'm on a different PC so haven't all your info to immediate hand... but this might help 'till tomorrow. I'm still not really happy with Q613 readings and I know this all gets confusing too. The devil is in the detail with these numbers
1. With your red lead on E and black on B you measure minus 0.6 volts. That means the base is higher than the emitter and so the device should be OFF. That appears not to be happening as you have plus 60ish on the collector.
2. The 1.5 volts that you seem to be able to get across this junction with Q617 not shorted again should turn this transistor off.
A quick and dirty test... remove Q613 and see if the voltage on Q617 (still shorted) falls to near the minus supply rail.
If it does replace Q613 but leave the BASE unsoldered and floating. Again see if the Q617 volts falls away. If it doesn't then Q613 is faulty (leaky).
I'll be back on usual PC tomorrow... and maybe that will give you something to go on.
Rotel RB-1010 power amp varistor! Rosscopecotrain Solid State 25 14th January 2013 08:32 PM
Rotel RB-871 Mark II Channel Imbalance dtm1962 Solid State 20 25th July 2011 04:01 AM
Rotel RB 990BX Cicuit Protection The Kook Abides Solid State 1 1st February 2011 01:49 AM
FS: Rotel RB-976 6X60 power amp Bill Fitzpatrick Swap Meet 4 14th April 2005 01:27 AM
Rotel RB-990BX Supply Voltage tab30 Solid State 4 22nd August 2003 04:09 PM
Copyright 1999-2017 diyAudio
