Help Needed: Excessive DC Offset/Imbalance - Rotel RB-990BX Power Amp
Old 10th October 2012, 12:40 PM   #61
dtm1962 is offline dtm1962  Canada
Thanks guys ...it is strangest thing I ever seen in an amp.
I will do more measurements tonight and update.....
Thanks again....
Dan
Old 10th October 2012, 01:25 PM   #62
Mooly's Avatar
No problem. We don't give up that easily
Old 10th October 2012, 07:16 PM   #63
jitter is offline jitter  Netherlands
jitter's Avatar
Indeed, I had to persist to find the cause of very strange fault in my CD-player, but eventually (2 years later), I did.
Old 10th October 2012, 07:39 PM   #64
Mooly's Avatar
That ones going back a bit. Must have missed it first time around so well done Faults like that are real odd balls but its really satisfying to stick with them and fix them.
Reminds of a guy at work (this was years ago and... and he was one of our best bench techs) who had an Hitachi D980 ? top of the range cassette deck and it would always throw a wobbler at the most inconvenient time by shutting off or going into some wrong mode. He'd checked absolutely everything you could think of so in frustration brought it into work for a joint effort.
Long story short, and I said as a joke that all that was left were the fuses on the PCB. Reply "if that fixes it you can have it" Hitachi x*7"3&^* junk. Guess what We replaced them and it never missed a beat afterward. The wire must have parted at the end caps or something. It was so funny... he kept the deck though.
so if dtm1962 is reading all this. Well we'll get a result with this one too
Old 10th October 2012, 10:40 PM   #65
Yes I am home now and I am going to do all measurements and plot on a marked up schematic. I will measure the frontend right thru to the Q617...
Stay tuned...
Thanks,
Dan
Old 11th October 2012, 02:44 AM   #66
Default Update on Measurements
Hi Guys : Please review the 3 (actually 4 sets of measurements) attachments
Observations & Notes:
1) Lifted one lead of all 3 Polystyrene pF range caps - no effect....
2) Measured Q613 (Black on C & Red on E) in Mohm range = measures OPEN
3) Measured Q615 (Red on C & Black on E) in Mohm range = measures OPEN
4) All measurements on 3 attachments is with Q617 shorted (C & E)
Attachment # 1 Q613 BASE lifted
Attachment #2 Q613 IN CIRCUIT
Attachment #3A Q613 REMOVED
Attachment #3B Q613 & Q615 REMOVED
My feeling is that Q613 is SHORTED & Q615 IS OPEN.
Let me know what you think.
Thanks in advance,
Dan
Old 11th October 2012, 02:49 AM   #67
Default Observation on Attachment #1
Even with the BASE of Q613 LIFTED from the circuit, I measured +51.3 VDC on the BASE PIN which was "floating above the PCB". So does that say the EMITTER (@ +56.7VDC) was leaking to the BASE?
Let me know.
Thanks,
Dan
Old 11th October 2012, 03:37 AM   #68
tauro0221 is offline tauro0221  United States
At this point the only left it is to replace all 3 transistors with new one and leave Q619 and Q619 out. Maybe somebody have a better suggestion.
Old 11th October 2012, 03:39 AM   #69
OOOps Should read leave Q619 and Q621 out.
Old 11th October 2012, 05:56 AM   #70
jitter's Avatar
What I find remarkable is the difference in currents through R623 with each measurement.
First set: 52 mA;
Second set: 15 mA;
Third set A: 66.7 mA ???? With Q613 removed, both ends of R623 should read the same voltage (i.e. 0 mA current). This looks like an error in measurement, please repeat.
Third set B: unknown, I'd like to know the value in this situation too, just to rule out leakage across the PCB (unlikely but not impossible).
Q613 sure looks questionable to me.
Edit: Q615 cannot be open. If that were the case, the voltage across R629 would be 0 V.
In the first two sets of measurements, it's open and conducting 38 mA, in the last it's not and the current drops to near 0, as expected.
Help Needed: Excessive DC Offset/Imbalance - Rotel RB-990BX Power AmpHide this!Advertise here!
Rotel RB-1010 power amp varistor! Rosscopecotrain Solid State 25 14th January 2013 08:32 PM
Rotel RB-871 Mark II Channel Imbalance dtm1962 Solid State 20 25th July 2011 04:01 AM
Rotel RB 990BX Cicuit Protection The Kook Abides Solid State 1 1st February 2011 01:49 AM
FS: Rotel RB-976 6X60 power amp Bill Fitzpatrick Swap Meet 4 14th April 2005 01:27 AM
Rotel RB-990BX Supply Voltage tab30 Solid State 4 22nd August 2003 04:09 PM
