Help Needed: Excessive DC Offset/Imbalance - Rotel RB-990BX Power Amp
Old 17th October 2012, 11:22 AM   #121
dtm1962 is offline dtm1962  Canada
Hi Guys:
Right now the DC offset has settled at 65 mv
with an actual speaker load....
If in the future it actually becomes audible in any
way ... I will build a simple Vbe tester using
a +/- PS with a 4 resistors/ diode circuit
and match the Vbe to get under 10 mV..
So guys I appreciate all the help to repair the amp!
It was an adventure for sure .... Lesson learned
..... ensure the parts that you put in are actually what
they are tagged.... Measure & confirm and
Don't make assumptions!
Dan
Old 17th October 2012, 11:57 AM   #122
Mooly's Avatar
Your welcome and its great to see you achieve a good result. In fact I've learnt quite a bit about that particular configuration by the simulations too.
65 mv, that's quite acceptable and it won't be and won't ever become audible. It will never change or drift with age either. Nothing to worry over.
Old 17th October 2012, 11:59 AM   #123
east electronics is offline east electronics  Greece
east electronics's Avatar
wait ... do you say that you have 65mv of offset with a load connected ??? if so that is a very wrong practice and you should measure the offset without a load ...
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 17th October 2012, 12:39 PM   #124
wahab is offline wahab  Algeria
Originally Posted by Mooly View Post
That would be a logical assumption but it doesn't seem to work like that for this type of configuration. Different input bias current don't seem to alter the offset. I tried 10k and 100k (now thats unbalanced) yet the offset is still in single mv figures. It does seem to purely rely on the matching of the semiconductors.
You cant draw conclusions from a simplified schematic..
What i did is to simulate the complete amplifier schematic since
i had it on a simulation file and equaling the bias resistors yielded
100mV output DC voltage variation.
Old 17th October 2012, 12:40 PM   #125
I left the unit for 3 hours without load and it @ 75 mV. I felt
Confident that it was safe to connect to speakers hence testing
With actual speakers at an average 5 watt output as per voltmeter
Calculation via AC setting and also measured Dc Offset via DC
Setting which settled at 65 mV.
Dan
Old 17th October 2012, 12:57 PM   #126
Mooly's Avatar
Appreciate that and that simulation is only part of the story (really must get a new signature ) I never tried equalising the bias resistors... and I'm on another PC so haven't got the file to hand to try. I'll try it when I get chance
Old 27th February 2014, 12:22 AM   #127
srinath is offline srinath  United States
Default Just bitten
Originally Posted by dtm1962 View Post
So guess what?
The PNP 2SA1142 measures as a NPN!!! Via Diode test and hfe test... D*MN!
Since the original NEC 2SA1142 is a green body unit.....and this was a black body unit....I should have noted...
I just got bitten by this too.
On my Marantz 2325 the a818 I was replacing with the A1142 actually is fine.
Its matched pair the c1628 was bad.
Can I run the a818 and the c2682 (replacement for the c1628) in the amp - will it hurt it ?
Cool.
Srinath.
Help Needed: Excessive DC Offset/Imbalance - Rotel RB-990BX Power AmpHide this!Advertise here!
Rotel RB-1010 power amp varistor! Rosscopecotrain Solid State 25 14th January 2013 07:32 PM
Rotel RB-871 Mark II Channel Imbalance dtm1962 Solid State 20 25th July 2011 03:01 AM
Rotel RB 990BX Cicuit Protection The Kook Abides Solid State 1 1st February 2011 12:49 AM
FS: Rotel RB-976 6X60 power amp Bill Fitzpatrick Swap Meet 4 14th April 2005 12:27 AM
Rotel RB-990BX Supply Voltage tab30 Solid State 4 22nd August 2003 03:09 PM
Copyright ©1999-2017 diyAudio
