Old 29th October 2003, 06:50 AM   #11
Ppl,
thanks for your suggestions. I will use an output resistor, of
course, but have never heard of/thought of the ferrite-bead
method before. As with many things, it is obvious in retrospect,
when somebody tells you. I am not sure i will need it, though.
I will also consider the other suggestions you made.
However, my original problem was solved by jcx. Of course,
if someone had told me to draw a unity-gain op amp
configuration, I would have done it right. But I was so stuck
into my design and various historical design decisions in it
that I missed the obvious.
Simple discrete unity gain buffer tcpip Solid State 111 7th June 2007 05:55 PM
Unity buffer from 7-pin triode? aletheian Tubes / Valves 11 16th December 2006 10:40 PM
Unity gain buffer in front of or behind TVC? KT Chip Amps 9 26th March 2006 09:02 PM
Unity gain NFB speaker-buffer Skorpio Solid State 11 30th October 2005 09:28 AM
Unity Gain Tube Buffer AKSA Tubes / Valves 41 2nd January 2004 10:11 AM
Page generated in 0.07418 seconds (67.90% PHP - 32.10% MySQL) with 11 queries
