diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   unusual amplifier topology jfet (http://www.diyaudio.com/forums/solid-state/220737-unusual-amplifier-topology-jfet.html)
kisshu 30th September 2012 07:51 PM
2 Attachment(s)
I'm trying to understand this unusual amplifier topology from the 1980's
revox b285 receiver. It has a jfet differential pair with bjt cascode but i don't understand the circuit above or the vas section; also there is an unusual use of an ic dual opamp LF353 in the global feedback circuit. would anyone like to help descibe the topologies starting with the IPS?
there maybe improvements to make to the circuits as well.
thd is listed as <.03% 20-20k
<.005% at 1khz 70 watts into 8ohms
dynamic headroom 2.5db 8ohms
rise time 4us 8ohms -( not sure how it relates to slew rate?)
Its an interesting topology to analyze and learn about.
Bensen 30th September 2012 08:56 PM
Hi there,
If I understand you correctly, you are speaking of the two upper BJT's where the Base's are connected to eachother.
==> do a search for "current mirror".
kisshu 30th September 2012 09:13 PM
it looks like a current mirror but the way its connected looks strange booth collectors are connected to the cascode collectors it looks like a quad current mirror? how does it work with that 100k R? is it stabalizing the cascode?
kisshu 30th September 2012 09:17 PM
also there is a 2 circled that appears in various places in the entire schematic anyone know what that would refer to?
alex mm 1st October 2012 07:16 PM
.......this components marked 2 in circle ,are composed by 2 pices , C100 it's
5.6pF aded with 22 pF , see BOM list , and you will descover :)
knutn 1st October 2012 07:57 PM
Originally Posted by kisshu (http://www.diyaudio.com/forums/solid-state/220737-unusual-amplifier-topology-jfet-post3185255.html#post3185255)
It's a normal current mirror, but the 100k resistor is lowering the open loop gain (and increasing the bandwidth) of the input stage.
sreten 1st October 2012 08:11 PM
Originally Posted by kisshu (http://www.diyaudio.com/forums/solid-state/220737-unusual-amplifier-topology-jfet-post3185171.html#post3185171)
Its probably a DC Servo to control the outputs DC offset.
rgds, sreten.
davada 2nd October 2012 01:31 AM
Hi kissue,
The circuit above is a current mirror. It increases the gain of the input stage by raising the impedance of the load on the cascode transistor collectors. The current drawn in the inverting leg, with respect to the inputs, is mirrored in the non inverting leg of the current mirror. Of course the signal itself is inverted. The VAS is an ordinary one with a buffer transistor emitter coupled to the VAS transistor. This increases the gain and bandwidth of the VAS and isolates the input stage by increasing the impedance, again reducing the load on the IPS. Together this topology can increase the gain as much as 1000 times or more. The diode D403 is just a clamp to help prevent sticking if the amplifier is driven to clipping. The VAS is coupled in a folded cascode to the next stage. It's a two stage VAS.
CBS240 2nd October 2012 01:55 AM
It appears to be an integrator for DC servo control.
Not to belittle an existing design but there are a couple of things I would have done differently. A Wilson mirror in the IPS would keep Vce and thus Pd of the mirror transistors equal. Or, I would have used a cascode arrangement, i e common base instead of a Zener for the buffer that feeds the folded cascode VAS. This way you could use a low Vce small signal device that has a large current gain, like a 2N5087 or a even a J-fet and eliminate a stage within the global loop. But then this is why I make my own amps.:p
kisshu 2nd October 2012 06:55 PM
Originally Posted by sreten (http://www.diyaudio.com/forums/solid-state/220737-unusual-amplifier-topology-jfet-post3186534.html#post3186534)
rgds, sreten.
Isn't it involved in the error correction? IC LF353 looks like its inverting the signal -some sort of high impedance inverting buffer that feeds back to the jfet differential pair? also the el capacitor appears to cause a filter effect. would like to know how it works.
Resources saved on this page: MySQL 18.75%
