Qtx powered speakers... - diyAudio
Old 30th September 2012, 10:54 AM   #1
amptech is offline amptech  Scotland
Send a message via MSN to amptech
Default Qtx powered speakers...
This unit came in with a cutting out fault!
After strip the unit down and looking at the amp stage I found poor soldering on the out transistors plus the bias transistor was not even bloted to the main heat sink. So after refitting the unit back together it was time for a power out put test... This unit is meant to be 350rms at best it was out putting 98w at 8 ohms and 4 ohm just over 150w before the clip led came on!
So how is it they are rated at 350rms!
Old 1st October 2012, 01:55 PM   #2
Also to add regarding this qtx unit the supply voltages are p/n 38v.....plus to get 300w or more the ht voltages should be highter...
Mixer to Powered Speakers Help jonholling PA Systems 13 23rd February 2012 11:46 PM
landscape powered speakers? dougr Class D 5 7th November 2010 06:51 AM
landscape powered speakers? dougr Solid State 1 6th November 2010 09:33 PM
Really Small Self-Powered Speakers Help??? brhoff Full Range 7 23rd February 2006 05:56 PM
Solar powered traveling speakers? has it been done? jizmmunki Multi-Way 0 16th April 2003 05:07 PM
Copyright 1999-2017 diyAudio
