Opinions on the eBay amp modules - EBB250 - diyAudio
Old 29th September 2012, 09:17 PM   #1
JPM14 is offline JPM14  United Kingdom
Default Opinions on the eBay amp modules - EBB250
Has anyone tried these? It is a mosfet module similar looking to a Maplin amp with an L bracket. The main difference is that it uses IRFP240 / 9240 vertical fets. There is a temp compensation thermistor built in. I have two which I bought recently. They seem to work quite good. 30 it costs for the bigger of the two boards which has 4 fets.
Old 29th September 2012, 09:27 PM   #2
Bone is offline Bone  United Kingdom
Can you post the circuit, you can't quite see it on eBay?
Old 29th September 2012, 09:45 PM   #3
will have to dig out the sheets that came with it and put it on. It is almost the same as the Maplin circuit but has an extra transistor where the usual 47k dropper resistor is from the +ve rail to Tr1 and Tr2
Old 30th September 2012, 08:17 AM   #4
The trouble with the Maplin circuit is that it is only suitable for Lateral Mosfets which have a negative thermal coefficient. Using vertical FETS like the IRFP240 etc will need the 1k variable bias adjust pot replacing with a bias transistor mounted on the heatsink, otherwise if used hard, thermal runaway could occur destroying the output transistors.
Old 30th September 2012, 10:42 AM   #5
Yes but the EBB250 is slightly different and has a thermistor (on the L bracket) in parallel with the bias pot. I have tried it from cold to 90C and the quiescent current remains constant enough to ensure thermal runaway won't happen
Old 17th April 2017, 03:39 PM   #6
treuben is offline treuben  Australia
How was reliability in the end? These modules still seem to be around. 8) I'm thinking of using one to replace a blown Chinese sub amp.
6L6 SE Tube Amp Kit on eBay... opinions? bermtoog Tubes / Valves 12 19th February 2012 06:53 PM
ebay TA2022 amp board w/tube pre ..opinions? Bill poster Class D 5 12th June 2011 12:32 PM
Ebay 15W class-a zero feedback modules? sharpi31 Solid State 4 24th July 2009 11:24 AM
cheap Chinese amp modules on ebay . Anyone know what they are ? jives11 Chip Amps 36 28th November 2008 04:35 PM
cheap eBay chip amp modules! Juicie Chip Amps 7 25th October 2008 03:48 AM
Copyright 1999-2017 diyAudio
