Amplifier using mosfet irpf9240 ispf240 - diyAudio
Old 29th September 2012, 12:51 PM   #1
Default Amplifier using mosfet irpf9240 ispf240
Hi
i watch on you-tube and wandering why he is using so big capacitors
with irpf9240 ispf240...
If we will have a look to av800 or av1000 amplifier capacitors are 47uf
Diy Class-A mosfet amplifier A-75 - YouTube
http://pro-radio.ru/user/uploads/11566.pdf
Old 29th September 2012, 01:12 PM   #2
http://www.youtube.com/watch?v=N4lUSM6TRZk
Old 29th September 2012, 01:16 PM   #3
Hi
If i will change this capacitors with higher capacity:?
Old 30th September 2012, 12:17 PM   #4
What about this amp
Old 30th September 2012, 01:04 PM   #5
just another
wintermute's Avatar
moved to solid state.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 30th September 2012, 01:56 PM   #6
JPM14 is offline JPM14  United Kingdom
I've seen that amp before, the one with 14 or 20 o/p devices for 800 or 1000w output - there is also a very handy tip at the end showing matching these fets using nothing more than a 15v supply, 150R 1w res and a voltmeter. I was going to ask about fet matching on here but thought it might be something that required some more sophisticated equipment.
Old 30th September 2012, 02:41 PM   #7
kevinkr's Avatar
Nautilus804 do not repeatedly post the same message to this and other threads. Stop SPAMMING the forum. Restrict further posts on this subject to this thread ONLY. If you do not understand English well please use Google Translate to understand this warning. If this continues disciplinary action will be taken. Last warning.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 30th September 2012, 04:18 PM   #8
sorry guys
Old 1st October 2012, 01:46 AM   #9
Originally Posted by JPM14 View Post
I've seen that amp before, the one with 14 or 20 o/p devices for 800 or 1000w output ....
You mean this DIYAudio member?
http://www.aussieamplifiers.com/products.htm
Ian
Old 1st October 2012, 09:35 AM   #10
No, click on the file on the opening post - 11566pdf, it is a good read about the whole project plus the fet matching trick.
Mosfet Amplifier Telnet100 Solid State 4 8th August 2012 09:53 PM
300w-mosfet Amplifier Help AUDISOUL Car Audio 3 31st December 2008 08:28 AM
MOSFET amplifier ash_dac Solid State 6 5th December 2006 08:55 AM
MOSFET/MOSFET amplifier jarek Pass Labs 21 22nd June 2004 05:04 PM
Copyright 1999-2017 diyAudio
