Old 28th September 2012, 01:37 PM   #1
Default using home amplifier for car
hi.
I have yamha B4 its 30W class A per channel . i want to use it in car.
I plan to use a 12V to 110V inverter to power the amp.
Is it a feasible option?
please advice
Old 28th September 2012, 01:44 PM   #2
KatieandDad's Avatar
Yes.
Old 28th September 2012, 02:03 PM   #3
RJM1 is offline RJM1  United States
Yes but. #1) if you mount it in the trunk it might get too hot on a hot summers day especially since it is running class A. #2 most home amplifiers are not designed for the vibration environment of a car and may become noisy, intermittent, or just stop working after a short period of time.
Your mileage may vary.
Old 28th September 2012, 02:32 PM   #4
thanks ,
my question was in relation to car engine.ignition noise?
I suppose the car line is more noisy than mains.
Secondly i have wto yamaha B5 which is 200w into 8 ohm and 320 W into 4 ohm, which i believe is plenty for my front and rear components rated 4 ohm each,getting a decent car amplifier with equally good SQ would be a relative challenge hence this option/though?
Any comments on this approach?
Old 28th September 2012, 06:40 PM   #5
if those amplifiers do not have a switch mode transformator then You have to use an inverter that has real sinewave output.
modified sine output inverter may work, or may damage your amplifiers.
Actualy it would cost a lot to get a real sine inverter that can handle high output powers.
might as well simply trash the original powersuppy of the amplifiers and make a swiitchmode one that has the output voltage/current capability to run Your devices.
Car stereo home audio amplifier capcat Car Audio 8 25th April 2012 12:35 PM
Home sub to car, possible? dztryr Subwoofers 3 6th August 2008 01:36 PM
Bypassing car amplifier SMPS for use in home 96tahoe Car Audio 8 3rd April 2008 09:50 PM
Another car amplifier at home thread... camusmuse Solid State 19 9th November 2004 11:22 PM
car amplifier for home sub? trespasser_guy Multi-Way 9 9th April 2003 03:29 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
