Old 28th September 2012, 08:44 AM   #1
tomst is offline tomst  United Kingdom
Default speaker coupling and power supply caps
Hi
I have a leak stereo 70 the PS caps have died and the the speaker out put caps on the way out i will also replace the rest of the
The amp has a 55 v out put from the transformer and and 75v power rail.
the two ps caps C6 and C7 are in parallel and measure 1250µf 100vdc each my question is can i up this to a bigger value if the diodes (or if i fit some diodes) handle it. if so what would be a good value. I have the same question for the speaker out put/coupling caps what value and what make model, these are rated at 2000µf 50vdc.
I was thinking Panasonic fr/fm/fc for the power pre amp, something like Panasonic ed for the power supply. and was going to use something a little more exotic in to couple the speakers. however most exotic caps don't come in values mentioned. looking at the diagram i think i should up the vdc of the speaker caps because if/when the o/p transistor go it will destroy the speakers.
Also is there a formula to work these values out.
if it helps the amp is 35w/channel
Thanks Tom
Old 28th September 2012, 06:44 PM   #2
within reasonable limits You can upgrade the C6 and C7 caps.
Something like 2200 Ufd / 100 V will work.
The output capacitors can e upgraded, yes. Even to 10x larger values, as long as they can handle least 50v.
I would allso add to C6/C7 a 100 nf foil capacitor too.
Old 28th September 2012, 08:40 PM   #3
Thanks for replying
I'm guessing C6/C7 PS caps are palled to up the capacitance in limited space so original 1250µf+1250=1500µf? so upping the capacitance to 2200µf+2200µf = 4400µf?
any advice on which make of cap to use on the output C34
A dumb question on amplifier power supply and output cap coupling d3aPentode Solid State 4 17th July 2010 04:48 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
Inductive coupling between power supply inductors pjpoes Parts 0 21st May 2007 05:22 PM
Power trans coupling with speaker, causing hum slowpogo Parts 0 15th January 2007 01:59 AM
Power supply caps Ellen Parts 4 4th July 2003 02:11 AM
Copyright ©1999-2013 diyAudio
