Advice on converting Yamaha B4 stereo to monoblock
Old 27th September 2012, 07:21 PM   #1
muddasirwaheedmalik is offline muddasirwaheedmalik  Pakistan
Default Advice on converting Yamaha B4 stereo to monoblock
Hi
I have just converted the XLR output of my Krell KRC-HR preaamplifier to 2 RCA connections. grounding the shielding wire with pin 1.
The B4 is 30W per channel rated for 8 ohm only.
The plan is to use it as a monoblock for 60W in bridged mode. I plan to use XLR to dual RCA for each channel , so two amplifierrs will give me two monoblocks 60W each.
BUT before venturing a test , i want to have opinions regarding system stability and heating??? would it be safe to do so as the amp would now see the 8 ohm load as 4 ohm??
BTW can anyone explain that is there any difference between balanced and bridged?
Advice on converting Yamaha B4 stereo to monoblockHide this!Advertise here!
Advice B4 Crossover Paul 4430 Multi-Way 5 27th January 2012 03:37 PM
yamaha B4 B5 amplifer Vintage muddasirwaheedmalik Solid State 9 11th January 2012 12:27 PM
B4 and using different pair of monoblock edwyun Pass Labs 11 2nd April 2011 06:42 PM
Yamaha BX-1 monoblock XEAGLEKEEPER Solid State 3 28th November 2009 09:47 AM
Monoblock Vs Stereo samsagaz Everything Else 12 27th April 2009 09:21 AM
Copyright ©1999-2017 diyAudio
