Hi all
I fond Motional feedback amplifier when i browsing it make some changes in original Philips 40 wats amplifier lat 1970s |
#2 |
Are you going to build it and if so what driver / box is it designed for?
Troy Thinking positive doesn't make things better, it makes you a better person. |
#3 |
Hi am build the old version a philips 40 WATS 1970s but this one is better because very low distortion original is also very good i used 10" woofer 1" tweeter shield enclosure
#4 |
So you used it full range? Why not bi-amp and use only on the low section? Is there any benefit to the tweeter / HF section?
#5 |
HI i prifard to use tweeter & woofer because this amplifier don't need passive filter with tweeter hi frequency response is very good can you give me some suggestion about this amlifier
#6 |
I don't know what you mean by suggestions, but to me a motional feedback amplifier would be used in the LF section of a bi-amped speaker.
I use a negative feedback electronic suspension system designed by Mr. Erath.
#7 | |
but could you elaborate why/how this amplifier don't need passive filter with tweeter hi frequency? is it because you have two seperate amp for low and hi part? (bi-amping with active x-over or passive network in front of the amp?) |
#8 | |
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Philips Motional Feedback (MFB) | steph_tsf | Solid State | 31 | 23rd August 2012 01:02 PM |
| new amplifier for 1970s powered advents | thetube0a3 | Chip Amps | 18 | 22nd February 2012 04:02 AM |
| Pressure based motional feedback. | tade | Subwoofers | 57 | 27th January 2007 03:01 PM |
| Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. | novtango | Pass Labs | 2 | 21st October 2002 01:50 AM |
| Page generated in 0.10226 seconds (100.00% PHP - 0% MySQL) with 10 queries |
