Main Filter caps upgrade ?
Old 26th September 2012, 12:50 PM   #1
qguy is offline qguy  Canada
Send a message via AIM to qguy Send a message via MSN to qguy Send a message via Yahoo to qguy
Default Main Filter caps upgrade ?
Is there a benefit in replacing main filter caps to boutique capacitors ? Will i get the same quality of sound as long as the caps are good? What would I expect if i upgrade to better caps ?
na
Old 26th September 2012, 01:32 PM   #2
DF96 is offline DF96  England
Do you mean mains filter caps, or PSU reservoir caps?
Old 27th September 2012, 08:33 AM   #3
not sure whats its called, its the largest caps in the amp
na
Old 27th September 2012, 09:32 AM   #4
They are the PSU reservoir caps. If they are old then changing them may improve the sound. If you pay a lot of money for the replacements then you will hear an improvement, and after you have told them how much you paid then your friends may hear an improvement too.
Old 27th September 2012, 09:58 AM   #5
R.I.P.
I like DF's reply.
If I was unsure about the old capacitors in the PSU, I may be tempted to replace them with standard commercial grade capacitors from reputable manufacturers as a first step to seeing if spending any more money could be worth while.
regards Andrew T.
Main Filter caps upgrade ?Hide this!Advertise here!
main ps cap upgrade for Marantz cd 67se crippledchicken Digital Source 2 30th June 2012 02:31 PM
Main Filter Caps/Bypass formula? patfont Power Supplies 6 5th September 2011 09:40 PM
Upgrade suggestions for mic preamp and main output tdashmike Chip Amps 1 5th March 2009 02:38 PM
Replacing main filter caps, need to re-bias? redrabbit Solid State 14 16th May 2007 01:20 AM
