To make this amp sound better
Old 25th September 2012, 09:08 AM   #1
jacobsetti is offline jacobsetti  India
Default To make this amp sound better
Hello friends
can somebody give suggestions to make this amplifier sound better
Jacob
Old 25th September 2012, 09:25 AM   #2
jaycee is offline jaycee  United Kingdom
Replace it.
Old 25th September 2012, 10:11 AM   #3
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
It's a very basic PA amp. As post two states, if the case is any good keep that, the rest would be better pushing up daisies.
Old 25th September 2012, 10:53 AM   #4
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Sorry, but this one to sound better will need
replacement or to switch it off.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 25th September 2012, 03:39 PM   #5
wg_ski is offline wg_ski  United States
Stone knives and bear skins technology, and the drawing is dated 2000????
You could build the whole thing out of op amps, with an LM3886 for the output and pickup two orders of magnitude improvement without even trying. It looks like something out of 1970.
Old 30th September 2012, 11:59 AM   #6
madtecchy is offline madtecchy  England
That scem loks very much like an eagle pa amplifier .
Old 30th September 2012, 12:20 PM   #7
Jay is offline Jay  Indonesia
Banned
From the fuse (10A), the transformer must be big enough for class-A amp. I predict it is a 150W amp.
You have +/-24Vdc (or 48V single ended high voltage, or 24V high current), enough capacitance, not so big heatsink. The output transformer I don't know what for, but choke supply is possible. I guess 7W class-A is possible. Higher wattage (JLH) is also possible if there is room for fan (may be externally).
Old 30th September 2012, 03:16 PM   #8
multisync is offline multisync  Canada
I only see +24vdc, ground. Those 4 diodes are not in a bridge configuration, they are in parallel. He will need a bridge etc...
Old 1st October 2012, 12:42 AM   #9
Ian Finch is offline Ian Finch  Australia
Get a real audio amplifier. A PA amplifier with an 8R monitor winding on the output transformer (like this one) does not make it suitable for music. Believe me, there are thousands of similar PA amp designs that were fine for that purpose but compromised on bandwidth and fidelity at every other stage.
IME, trying to open up the bandwidth of these old machines is more expensive and ineffective than a simple substitution of a cheap chip-amp as suggested in #5. If you can afford it for the sake of having a discrete design, then buy a kit of a basic 50-80W amplifier like Ebay NAP140, L6 etc.
Ian
Old 1st October 2012, 04:15 AM   #10
ChrisA is offline ChrisA  United States
Originally Posted by jacobsetti View Post
Hello friends
Jacob
People are saying to simply replace it. But what is the application? This looks like it is used for voice amplification in an auditorium. In that case you might do better thinking about acoustical treatments and speakers as that will improve the sound more than anything you could do to the amplifier.
The amp was never intended for use as a home HiFi. If you are trying to use it for that purpose, it would be mostly useless in that application. But the power transformers and chassis might be the start of a new project.
To make this amp sound betterHide this!Advertise here!
Why does my tube amp make a scratchy, popping sound? longdrive55 Tubes / Valves 12 11th August 2009 06:48 PM
Make Amps Sound Better PassFan Pass Labs 17 11th June 2007 01:14 AM
how to make tube amp sound layback and mellow? jj2 Tubes / Valves 28 10th April 2006 03:47 AM
How make sound by MCS51 ? ahmadabasi Digital Source 2 13th May 2005 11:20 AM
what is your favorite loundness or pre-amp or anykind of circuit that make good sound jinkuchi Solid State 11 9th January 2005 02:08 PM
Copyright ©1999-2017 diyAudio
