diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Op Amp buffer/amplifier, quasi-complementary, need advice. (http://www.diyaudio.com/forums/solid-state/220270-op-amp-buffer-amplifier-quasi-complementary-need-advice.html)
wponline 24th September 2012 02:07 AM
1 Attachment(s)
Hi guys,
Would need your help on how to improve this Op Amp buffer/amplifier with quasi-complementary output. I've had several blown driver and output transistors (Q3, Q4, Q5 and Q6) and with likelihood that the resistors (R74, R75, R76 and R79) getting toast as well. I've read several threads related to quasi-complementary and would like to seek your advice regarding improving this design.
1. Component upgrade. Better driver/output transistors combination. How will it affect the resistor values?
2. Using a Baxandall diode/JLH diode. All amplifiers of this type I saw have the NPN driver/NPN output transistor connected to the positive supply and the PNP driver/NPN output transistor connected to the negative supply. A resistor, diode and capacitor is connected between the output and emitter of the PNP driver transistor. In my attached image. Should I connect the resistor/diode/capacitor between positive supply and emitter of PNP transistor?
3. Upgrading the P/S to a capacitance multiplier?
Thanks in advance for your comments and reply.
Nuki
djk 24th September 2012 09:37 AM
Why are you using the 2N6259?
Why not use the 2N3055/MJ2955 pair?
That circuit looks like it has a lot of room for improvement.
jcx 24th September 2012 01:52 PM
save power supply, heatsink, use chip amps?
wponline 24th September 2012 02:17 PM
Hi djk,
The 2N6259 is the original part.
Actually I've tried MJ15024 with moderate success. I think that the pre-driver and the driver needs to be upgraded to more modern parts. The pre-driver 2n2222a and 2n2907 have a different resistor in their collectors, 510 ohms and 1kohms, why this is so? If I change to a really complementary pair, will they be equal? What value? Same with the 2n5320/22 pair, just curious why is the placement of the 33 ohms different? Most quasi-complementary I've seen don't have this resistor from driver to output transistor.
Thanks.
wponline 24th September 2012 02:22 PM
Hi Jcx,
You mean like a power op amp that would replace the LF412 and output buffer/amplifier?
Actually I just read the datasheet of an LH0101 and the op amp + output amp arrangement is similar except that the output is full complementary. This too is obsolete though.
Ian Finch 25th September 2012 01:00 AM
The problem, as jcx hints, is that the whole circuit is both obsolete and sub-optimal. It would be better to start again with a popular forum design from scratch, whether you reuse parts or not. Those power supply rail voltages would seem OK for some larger chip-amps which would perform much better than the attached schematic circuit. It would probably cost less than the necessary mods and still be much simpler by just plug and playing a cheap kit.
wponline 25th September 2012 01:47 AM
Hi Ian,
I was toying with the idea of implementing a discrete design based on the LH0101 and utilizing the same or better transistor combo but don't have the design skills to do it. The board which houses the amplifier also contain the adjacent DAC circuit and associated logic. This is then housed in a constrained module. So putting a power chip amp is not possible at this time.
So going back to the 1st thread, optimizing the circuit which you mentioned is the way to go, better transistor combo or some circuit trickery will do. I hope to learn a bit of designing in the process, I think.
Thanks.
counter culture 25th September 2012 02:21 AM
The circuit as drawn is... strange.
Where is the +/- 12V coming from? The circuit has too many problems. Quasi-complementary is rarely used now other than for junk-box amplifiers where somebody is scrounging around to build an amp from available parts or for some other unusual reason.
The best thing really is to forget this circuit and pick another one.
What is the signal source? What is the impedance of the output transducer (speaker)? How much power output is really necessary?
Is stereo required?
If you answer these questions we can recommend a circuit that will be more educational or cheap. If you make your objective understood it will make for a more focussed recommendation.
counter culture 25th September 2012 02:29 AM
I see you have partially answered some of the questions in a cross-post.
Post a picture of the space into which the amp must fit if you can and answer the questions to the best of your ability. It may still be possible to remove the existing amplifier components and stick in a new board with doublesided tape.
Also post details of any preceding circuit.
jcx 25th September 2012 02:41 AM
monolithic audio power amp chips - check the chip amp forum - LM3886, LM4780, TDA7293 are all pretty complete amps, have many project articles - sometimes known as "Gain Clones"
most have output protection, thermal overload protection circuits built in too
Copyright 1999-2017 diyAudio
