Blow out! :-)
Blow out! :-)
Old 19th September 2012, 07:06 PM   #1
KLR650 is offline KLR650  United Kingdom
Default Blow out! :-)
Pushed this effort a little too far ;-)
Glad I was several feet away when it went lol
Old 19th September 2012, 07:14 PM   #2
Pano is online now Pano  United States
Pano's Avatar
Blow out! :-)
That is not a happy transistor!
Old 19th September 2012, 07:21 PM   #3
adason is offline adason  United States
adason's Avatar
that capacitor looks even less happy, maybe thats what it all started...you breach the cap, you get dc where you do not want to, there goes transistor
Old 19th September 2012, 07:22 PM   #4
tvrgeek is offline tvrgeek  United States
Ah grasshopper, you must strive to keep the smoke inside the wires.
Old 19th September 2012, 07:30 PM   #5
But Master, I leave no trace on the rice paper! lol
I think I exceeded the power dissipation - worked fine 100V p to p and 500Hz but shortly after increasing to 1KHz it went (I'm driving a piezo stack). Exciting! :-)
BTW, I'm running it off +120V and -20V - hope this hasnt got anything to do with it?
Old 19th September 2012, 08:24 PM   #6
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Put a schematic up maybe we spot something. I may be mistaken but is an array of Piezo drivers not extremely capacitive?
Kindest regards
Nico
Old 19th September 2012, 10:54 PM   #7
jaycee is offline jaycee  United Kingdom
In the style of Mortal Kombat.... TOASTY!!
Old 20th September 2012, 01:49 AM   #8
wg_ski is offline wg_ski  United States
Most TO-220 transistors have absolutely horrible SOA above about 30V VCE. They may be only good for 5 or 10W (or volt-amps) driving a purely reactive load at those rail voltages. I'd start with something bigger, run the drivers at high bias and use base stoppers to avoid parametric oscillation (the burst-of-oscillation-on-part-of-the-cycle phenomenon).
It may have also gone into cross-conduction and then the current goes completely out of control. Speed differences between NPN and PNP show up with a vengence driving a capacitor.
Old 20th September 2012, 05:55 AM   #9
Thanks for that.
I dont have a diagram to hand to post but I'm using a IRF630/9630 in a simple design - the bias set by a variable resistor but with a NTC thermistor in parallel to offer some thermal control of the bias. I'll try a more robust output pair and maybe have a low value resistor in series with the output for some isolation. Good fun though!
Blow out! :-)Hide this!Advertise here!
It will probably blow up blistard The Lounge 13 6th December 2011 08:35 PM
NAD fuses, slow blow or fast blow? AllCaster Solid State 3 25th October 2009 06:11 PM
Blow up once, Blow up twice and Blow up somemore S.C Chip Amps 14 6th March 2005 12:09 AM
Will This Blow Up? Trout Instruments and Amps 8 6th February 2005 12:52 PM
Will it blow up? dickerbeen Everything Else 1 17th April 2003 05:21 AM
Copyright ©1999-2017 diyAudio
