Op-amp Buffer
Op-amp Buffer
Old 27th October 2003, 01:44 AM   #11
Christer is offline Christer  Sweden
As I said, I suspect the bridged diamond buffer to have the
be the best performing of the alternatives discussed. Besides,
It will dissipate less power in the transistors, making cooling
easier, PSU req. slightly less demanding, at a slightly higher
component count and complexity. However, If you do not
absolutely need a bridged setup, I would suspect a single
diamond buffer performs well enough. I hope to experiment
with one soon myself.
BTW, unless you have already read it, I strongly recommend
reading Walt Jungs article on the discrete diamond buffer:
"Walts Tools and Tips, Op-Amp Audio, High performance
buffers (part II): Electronic design, Oct. 1, 1998".
I don't know if it is online still, though.
As for my effort, it was quite interesting and educational for
myself too. ´Trying to answer other peoples questions often
force you to think deeper on the issue which sheds new light
on it. Being a university teacher, I stronlgy believe in the
idea that you don't really know a course until you have taught
for a couple of years.
Old 27th October 2003, 05:54 PM   #12
johnferrier is offline johnferrier  United States
johnferrier's Avatar
Okay, I now favor the diamond buffer (rather than the half diamond), but still plan to use a bridged (double-diamond) outputs. I'm willing to pay for a little more performance. Since, the symmetry-bridged topology does nothing for odd-order distortion, I will also see if I can find techniques to lower that too (does this mean MOSFETs?). I will search around.
Also, I did find Walt's article for op amp buffer, using the Wayback Machine--the internet archive.
And yes, I learn by trying to answer questions too (usually, I learn that I don't know quite as much as I thought).
Thanks and good luck with your circuitry!
JF
Old 27th October 2003, 06:58 PM   #13
PRR is offline PRR  United States
PRR's Avatar
The constant-current "Class A" topology dissipates twice the power of a true push-pull Class A amp. Here you are dissipating 4.8 watts to get 0.95 watts in the load; push-pull Class A with the same drop-losses would be under 2.5 watts heat. This may not be too important at headphone levels.
With the constant current topology, device current swings from zero to 160mA; with push-pull it swings zero to 80mA. The lower swing tends to less distortion. The difference may be too small to worry about.
As noted, you will need a 4-wire headphone connection, not the usual 3-conductor plug, but I assume you saw this.
What are all those resistors??? Why have you taken a Diamond and cut one side off? Those resistors are to make both sides of the diamond play nice together. The 10 and 1Ω Emitter resistors set the currents, but here you have set current with current sources so you do not need bias resistors. The 10Ω emitter resistor adds impedance to the drive of the output transistor which we really don't want. The 1Ω emitter and and 10Ω load resistors just waste power, you don't need either one. The 1K gives problems when the two sides of the diamond do not cancel bias current, and is worse when there isn't any cancellation at all.
Why even have two stages? For 80 or 160mA peak output current, any good little transistor needs only a couple mA base drive, well within the ability of any op-amp you are likely to use, even if you yank the opamp into class A. The B-E voltage variation does not cancel between first and second stage, so distortion of a one-stage design is not necessarily higher. Using one stage does mean, if you do not take DC feedback around the buffer, that there will be a 0.7V offset, but it will be the same at both sides of the headphone so there is no DC in the cans.
Then you have:
I've added a small resistor in the collector, to put some limit on fault current without much/any effect on sonic performance.
That will work quite well. Full push-pull both sides can be cooler and lower distortion, but now you need those emitter resistors back.
Interestingly, the Diamond can give lower THD if carefully trimmed in class AB than when working Class A. However the distortion spectrum shifts from mostly-low-order (Class A) to high-order (Class AB). You can make the 3rd vanish, but the 5th is unchanged, and the 7th rises a bit. The ear is the only judge of this.
Old 27th October 2003, 08:01 PM   #14
Richard C is offline Richard C  United Kingdom
In favour of SE operation:
Since music contains odd and even harmonics I think care needs to be taken in using configurations that favour one over the other. Push-pull looks attractive due to second harmonic cancellation but may not be the best in terms of sound quality.
The single ended design will produce higher total distortion but probably with a more even distribution of odd and even harmonics.
Old 27th October 2003, 09:11 PM   #15
With the disclaimers I stated that it is only simulation and that
there might have been slightly different load and bias
conditions, the result I posted indicated that the 3rd order
distorsion was the same for SE and diamond, while the latter
lacked 2nd order. It's difficult to predict from theory what the
ear will like, and many seem to think 2nd order distorsion
make wonders, but will 0.01% 3rd order distorsion really be
less disturbing if you "mask" it by a 10 times higher level
of 2nd order distorsion? It would be another story, perhaps,
if we could decrease the 3rd order distorsion at the cost of
increasing the 2nd and get a higher total distorsion figure,
but that seems not to be the case here.
The analysis is simplified and non-conclusive of course. PRRs
remark on biasing the diamond buffer to class AB was interesting.
Old 27th October 2003, 09:16 PM   #16
PRR,
First, thanks for your long post (discussing transistors) over on the Jung Regulator thread. I need more time to absorb what you wrote.
As far as heat, I've got relatively large heatsinks. And I plan to use 4 wires to the headphones--no problem.
The resistors, he...he...he... I wondered if anyone would say anything. I used those values (1 and 10 ohms) only because I read John Curl write that 15-18mV was an optimum value across Re (I used 20mV). Now that was for the emitter resistors.
I have the input (1k) and output resistor there so that I could parallel the circuit (probably only the output transistors though).
As far as two stage, well the diamond circuit uses two stages. However, the first stage is used to bias the output. I've got current sources to do that.
Richard C,
Yes, I'll try to balance the odd and even THD. You're suggesting SE achieves that.
Thanks.
JF
Old 27th October 2003, 10:04 PM   #17
PRR's Avatar
Not the same.
The harmonics in amplifier distortion are exactly 2X, 3X, etc the fundamental and always phase-locked.
The harmonics in music are (generally) not exactly 2X or 3X the frequency of the fundamental, and not phase-locked. (Synthesizers are an exception; electric guitars are a complex mix of string inharmonicity and amplifier harmonics.)
The ear may be fooled, mistaking amplifier low-order distortion for "richer music". However only tin-eared rockers (like me) should be fooled by high-order "harmonics", which in normal musical instruments are NOT multiples of the fundamental but in an amplifier are perfect harmonics.
And we use single-tone harmonic distortion just because it is an easy test/simulation. If you go to two-tone: two clarinets on one stage will not intermodulate each other (to detectable degree). Two clarinets through an amplifier always will IM. The IM on complex milti-tone signals (real music) can be astonishing even when THD is low.
I think that higher-order THD means more IM for the same percent THD; however that's not what we measure on current amplifiers. Maybe just because the THD is so low that we are not really measuring harmonic production. On old low/no-feedback amps, the 1:4 60:7KHZ IM number was pretty sure to be four times the THD number; but as we supress THD this old guide becomes invalid.
Neither one reliably "favors" musical harmonics, since the real musical harmonics are not perfect harmonics. If they were, then it might be possible for a high-2nd-THD amp to cancel the natural 2nd harmonic of an instrument, or boost it. In real life, the natural harmonic will go in and out of phase with the amplifier harmonic, "throbbing". The 3% or 10% THD numbers we accept on simple no-feedback amps limit "throbbing" to a small piece of a dB, ignorable.
Opinions and theory aside: we see happy music lovers with topologies from SE Triode to hyper-feedback. The ear must have a very complicated weighting rule for artificial harmonics. It clearly ignores 1% or more 2nd, yet complains painfully about a trace of 13th, yet another amp with slightly different trace distortion is well-loved.
Sometimes the best way to pick a configuration is to look at cost. In a loudspeaker amp, JF's plan would be mighty expensive (at headphone levels and with personal labor, this is no big deal). Instead of paying for oversized transformer and heatsink, you fancy-up a basic Class B stage to hold it in AB, reduce Gm nonlinearity, and probably (not always) add gain so you can use feedback.
Going back to JF's situation: as long as he's using op-amps anyway, an "absurd" yet perfectly workable plan is to get a couple dozen op-amps (cheaper in full-tubes) and parallel them (with appropriate connection so they don't fight). Most modern opamps JF would use for audio are loafing in 1KΩ. He could strap two quad-packs and drive 150Ω (one side of his bridge). That's 8 or 16 chips for stereo, but a simple design and perhaps a "simpler" distortion by omitting a booster stage. (IM multiplies with number of hard-working stages.)
Old 27th October 2003, 10:18 PM   #18
PRR's Avatar
For what?
28-30mV is a theoretical optimum for a Class AB push-pull emitter-follower amplifier with a very low impedance drive.
In Class A, that works (though bias stability is tough and higher is not bad).
Where the driver is not very-low-impedance, the optimum shifts. My impression for the Diamond Buffer with emitter resistors is that the optimum may be half of the above case. That may be Curl's 15mV-18mV, though without knowing where he wrote this I am just blind-guessing.
And 15mV or 30mV is all wrong for many other topologies.
Bias stability in the Diamond is not good, unless you match parts. And you can NOT match a PNP to an NPN. The resistivity is higher in PNP. You can match Vbe, or you can match Hib, but unless you carve them both on one waver and adjust the area of the PNP you won't get a good 4-way match. That turns out to be the practical limit on Diamond Buffer performance. It can be very-very good, but with real parts it can't match theory. And with real parts, it tends to have significant offset (output sits about 70mV more positive than input).
As to whether single-ended, push-pull, constant current, or light-bulb sources sound "best": IMHO, a well-designed version of any of these should be "faultless". Often the "sound" is not in the topology but in a capacitor (or some trickery needed to "avoid capacitors"). Sometimes we "want fault" to "enhance sound". I've been called a pragmatist and you should have different opinions and preferences, but I think any of the above will work fine if you get all the small details right.
Old 28th October 2003, 12:19 AM   #19
For what?
PRR,
I suppose he is referring to this post and some of the follow-up
discussion. Myself I have no opinion, not having read the
HP article.
http://www.diyaudio.com/forums/showt...296#post244296
Further, thanks for your very interesting discussion of
instument vs. amplifier harmonics, as well as for other
recent interesting posts here and in the regulator thread.
Old 28th October 2003, 04:22 AM   #20
Okay, here are sketches of my alternatives.
BRIDGED ACTIVE FOLLOWERS
JUNG DOUBLE DIAMOND BUFFER
I'm using a cross coupled OPA637s. (Concept found on last page of the AD8610 datasheet: http://www.analog.com/UploadedFiles/...D8610_20_c.pdf)
Initially, I had thought a simple active follower was a bit basic. But, now sketching it out with the cross coupling, it seems like it may have just the right amount of sophistication.
The double diamond is still appealling and I don't mind the extra work involved in constructing it. Which circuit is best?
The 2SC3953 (2SA1538 w/datasheets http://www.datasheetcatalog.com/data.../2SC3953.shtml) seems like a super part to use.
Let me last add, my initial plan was to use BUF634s (which I have). However, I really like to use discrete circuitry at the output.
Anyone have further thoughts???
JF
Op-amp BufferHide this!Advertise here!
B1 Buffer and some help please!!!! Malka07 Pass Labs 4 28th May 2012 07:18 PM
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 01:46 PM
Near ZERO IMD buffer amp wenye Solid State 37 20th April 2009 07:50 AM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
OP + buffer Holger Barske Solid State 13 3rd November 2001 09:13 AM
