replace adjustable regulator with fixed?
Old 17th September 2012, 12:29 PM   #11
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Doubtful it's continuous unless there are some heatsinking secrets to tell, but the current-limit curves do show it possible to pull a couple of amps through the regulator.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 17th September 2012, 12:54 PM   #12
AudioSan is offline AudioSan  Norway
the heatsinks has little to do with the current passing through it.
but more the voltagedrop. if one run 25V in and 12V out. you will need some "big sinks" to pull any current. but with 15V in and 12V out, thats a whole other story.
lets say 1A current. at 25V in. thats 13W dissipation. at 15Vin its only 3W.
Old 18th September 2012, 02:49 AM   #13
sofaspud's Avatar
I'll agree, but there is much to do with junction temperature (via the in-out differential, ie power dissipated in the reg, ie Tj), so heatsinking is quite relevant. There's current limiting and thermal shutdown to consider, so AndrewT is correct - it's treading into no-man's land.
Old 18th September 2012, 03:12 AM   #14
there is. but the difference between 1A and 2A is kids candy.
the difference from 3Vdrop to13-18V drop is a much bigger issue.
all diveces reach a maximum. but the main reason that a regulator fails, is voltage drop(dissipation). not the current that it draws.
Old 18th September 2012, 03:15 AM   #15
lets say a worst case. LM317 with 35V in and 5V out. at 1A. hell. thats 30W dissipation
not a easy task for a to-220die
Old 18th September 2012, 09:57 AM   #16
Audio
What pre regulation do you have for the implementation you have described in post7?
How much does the Vin vary?
How much could Vin vary for worst case operation?
Does Vin, with some ripple, drop low enough for regulator drop out to occur?
regards Andrew T.
Old 18th September 2012, 10:32 AM   #17
Vin is pretty darn stable.
worst case operation? do you think of in regards to heatsink?
Old 18th September 2012, 11:27 AM   #18
Well, guess what, I disagree with "pretty darn stable".
For 15Vdc @ 2Adc, I'd use 230:12Vac, 100VA transformer operating from 240Vac, feeding a bridge rectifier and 4u7F of smoothing.
Apply a -6% mains voltage variation. i.e. 225.6Vac for a check on whether regulator drop out occurs.
Input to regulator becomes a worst case low of about 14.8Vdc +-200mV of ripple. Giving a Vin from 14.6Vdc to 15Vdc.
Now apply a +6% mains voltage variation, i.e. 254.4Vac. to check for maximum Pd.
Input to regulator becomes a worst case high of about 16.72Vdc +-200mV of ripple.
For a 2A output the transformer is running at 50% o maximum continuous output and the regulator Pd varies from ~5.6W to ~9.4W
That is not "pretty darn stable".
The questioner should do something along the same lines as I have shown and insert his own data to arrive at his operational Pd and how much it can vary for his/her mains voltage variation.
regards Andrew T.
Old 19th September 2012, 03:23 PM   #19
i don't know about you. but over here i have never had more then about 2-3% variation on mains.
Old 19th September 2012, 03:56 PM   #20
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Over here the line voltage can dip into the mid 90's and run as high as 128 during the summer == i had our electric company put a data logger on the main panel.
We had a competitor whose a.c. power was cut in the summer of 2007 -- their thermal curing ovens were powered by natural gas and didn't cut out quickly enough during the initial stage of a brownout -- what a mess!
If it's a low voltage application, I would try replacing the LM317 with one of the fixed voltage regulators in the LT1963A series -- there are 4 fixed voltage choices.
replace adjustable regulator with fixed?Hide this!Advertise here!
push pull adjustable fixed bias hpupo Tubes / Valves 3 14th June 2011 04:25 AM
How to replace trimmer pot with fixed resistor? kptseng Solid State 9 8th August 2008 05:29 PM
Adjustable Fixed Grid Bias dsavitsk Tubes / Valves 5 4th December 2007 04:58 PM
Adjustable power supply to replace volume control Leolabs Solid State 8 11th July 2007 05:43 PM
