diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   What causes this 360 phase shift at ~20khz? (http://www.diyaudio.com/forums/solid-state/219849-what-causes-360-phase-shift-20khz.html)
Fusion916 16th September 2012 07:43 PM
2 Attachment(s)
In this simple common emitter stage there's an intentional pole at 10hz at the input and an intentional 180 phase shift due to the CE stage inverting gain stage but I want to understand what model parameter causes the 360 phase shift. Also, is this something I need to be concerned about? Rails are +/- 15V.
Here is the model:
.model mpsa18 npn (
+ Is=33.58f Xti=3 Eg=1.11 Vaf=100 Bf=2.365K Ne=1.579
+ Ise=166.7f Ikf=.1172 Xtb=1.5 Br=5.774 Nc=2 Isc=0 Ikr=0 Rc=1
+ Cjc=4.948p Mjc=.4109 Vjc=.75 Fc=.5 Cje=7.547p Mje=.3765 Vje=.75
+ Tr=800.3p Tf=310.1p Itf=.6 Vtf=6 Xtf=35 Rb=10)
Fusion916 17th September 2012 12:06 AM
Any guidance?
Dave Zan 17th September 2012 01:15 AM
If I understand your question correctly you mean the vertical line at ~20kHz?
This is just an artefact of the way the phase is displayed. It is not a problem.
Best wishes
David
Fusion916 17th September 2012 01:30 AM
Originally Posted by Dave Zan (http://www.diyaudio.com/forums/showthread.php?p=3167694#post3167694)
Best wishes
David
How is this an artifact on the way the phase is displayed? It goes from -180 to +180 instantaneously, so for some reason there is a +360 phase shift at this frequency.
volume knob 17th September 2012 01:57 AM
-180 is +180 ;)
Fusion916 17th September 2012 02:03 AM
Originally Posted by volume knob (http://www.diyaudio.com/forums/showthread.php?p=3167719#post3167719)
-180 is +180 ;)
The phasing is the same but a +360 degree phase shift is not "the same", its one full cycle of delay.
I would just like to know what is going on, calculation wise, in which there is a instantaneous 360 phase shift. I agree its not real, I just want to know where it comes from.
volume knob 17th September 2012 02:17 AM
Its a quirk in the way that degrees are displayed on graph, the + numbers are added to 0 degrees and the - numbers are subtracted from +360 degrees
If you can change you graph scale from -200 to +200, to a 0 to 360 scale it would make more sense
Dave Zan 17th September 2012 05:12 AM
In some software you can show the phase with(out) this display artefact with a check box called "Wrap phase" or some similar option.
Best wishes
David
JZatopa 17th September 2012 05:21 AM
Are you asking why isn't the phase flat all the way past 20k?
Fusion916 17th September 2012 04:00 PM
Originally Posted by DJNUBZ (http://www.diyaudio.com/forums/showthread.php?p=3167826#post3167826)
Yes.
And this is not really a "graphing" issue, as it's displaying correctly, the simulation data points just change from negative to positive. This is what I would like an explanation on:
1.659587e+04 6.032661e-04 -3.14125e+00
1.698244e+04 5.895341e-04 -3.14127e+00
1.737801e+04 5.761147e-04 -3.14129e+00
1.778279e+04 5.630007e-04 -3.14131e+00
1.819701e+04 5.501853e-04 -3.14133e+00
1.862087e+04 5.376615e-04 -3.14135e+00
1.905461e+04 5.254229e-04 -3.14137e+00
1.949845e+04 5.134628e-04 -3.14138e+00
1.995262e+04 5.017750e-04 -3.14140e+00
2.041738e+04 4.903533e-04 -3.14142e+00
2.089296e+04 4.791915e-04 -3.14144e+00
2.137962e+04 4.682838e-04 -3.14146e+00
2.187762e+04 4.576244e-04 -3.14148e+00
2.238721e+04 4.472076e-04 -3.14150e+00
2.290868e+04 4.370279e-04 -3.14151e+00
2.344229e+04 4.270800e-04 -3.14153e+00
2.398833e+04 4.173585e-04 -3.14155e+00
2.454709e+04 4.078583e-04 -3.14157e+00
2.511886e+04 3.985743e-04 -3.14159e+00
2.570396e+04 3.895017e-04 3.141580e+00 <---change from - to +
2.630268e+04 3.806356e-04 3.141562e+00
2.691535e+04 3.719713e-04 3.141543e+00
2.754229e+04 3.635042e-04 3.141525e+00
2.818383e+04 3.552299e-04 3.141507e+00
2.884032e+04 3.471439e-04 3.141488e+00
2.951209e+04 3.392420e-04 3.141470e+00
3.019952e+04 3.315199e-04 3.141451e+00
3.090295e+04 3.239737e-04 3.141433e+00
3.162278e+04 3.165991e-04 3.141414e+00
3.235937e+04 3.093925e-04 3.141395e+00
3.311311e+04 3.023499e-04 3.141377e+00
Copyright 1999-2017 diyAudio
