New Electrocompaniet AW120 clone
Old 14th September 2012, 11:17 PM   #1
hollow_man is offline hollow_man  Europe
Default New Electrocompaniet AW120 clone
This is what I have come up with. Design is largely based on AW120, except original protection circuitry, voltage amp power supply
and a small twist on input stage biasing.
Would anyone care to comment on the pcb design, as it is getting toward completion? Left and right channel signal paths are mirrored except around the output transistors, where I have tried to keep respective trace lengths equal.
What would you do in a different way? Any other comments/ideas are welcomed.
Cheers.
'in acts and works
bigger than a great wale's tail'
Old 14th September 2012, 11:21 PM   #2
That' d be the schematic.
'in acts and works
Old 30th September 2012, 03:25 PM   #3
garga is offline garga
Welcome
Very nice project!
I would like to ask for help
Electrocompaniet AW-180 schematics I need
Thanks for your help
my email address
gargafater@freemail.hu
Old 16th November 2012, 07:39 AM   #4
powjemini is offline powjemini  Greece
Hello hollow_man
I saw the schematic of the amplifier and i was wondering how the feedback network from the "OutR" works. It seems it goes to a 8K2 resistor, but i would expect a second resistor from there connecting to ground. As it is now it seems like being an amplifier with 0 dB gain.
Old 21st November 2012, 04:29 PM   #5
Hi Powjemini,
this design is along the typical EC lines, whereby the first section of the amp operates open loop as a transimpedance amplifier with a very high output impedance. However, it 'sees' the 8K2 output section feedback resistor as its load, which establishes a given voltage gain. The output section indeed operates with 100% negative feedback, so its voltage gain is unity.
Hence you could say that the voltage gain is determined solely by the 8K2 feeback resistor (within limits).
hollow
'in acts and works
Old 17th December 2012, 07:33 AM   #6
As you may know, down here in Greece we have as of late been shattered with deep salary cuts, very steep taxation, job losses etc, so sadly I cannot proceed to the elusive construction phase...
'in acts and works
Old 23rd May 2017, 03:08 PM   #7
jorgovanko is offline jorgovanko  Serbia
Hi hollow_man,
whether you complete this project?
Thx,
Old 24th May 2017, 08:50 PM   #8
Default AW120 diy clone
Hi jorgovanko,
just a hastingly taken picture of the AW120 clone machine as it stands. As a matter of fact, I have a new chassis specifically built for the purpose by a friend that is more spacious and offers better cooling, so I will be transplanting soon.
As I said I have given up on the higher power clone due to costs and time constraints.
Cheers.
'in acts and works
Old 25th May 2017, 06:31 AM   #9
A few more daylight pictures.
'in acts and works
Old 25th May 2017, 03:28 PM   #10
Realy nice...
Why you gave up from the first version of PCB? She was very good!
New Electrocompaniet AW120 cloneHide this!Advertise here!
Did someone clone an Electrocompaniet AW amplifier? vzs Solid State 38 16th May 2016 05:21 PM
High-Power Electrocompaniet clone hollow_man Solid State 38 17th October 2011 03:53 PM
Electrocompaniet aw120 HQ photos pcbs needed scsml Solid State 0 13th February 2011 01:39 PM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 09:19 PM
Copyright ©1999-2017 diyAudio
